Help with my MAX cold start issue
When i have a cold start over night of if the engine completely cools down i go to start it and it makes a weird grinding noise. But once the car is warmed up it doesnt make the noise any longer. Another problem i have been noticing that when the car is just started and i being to drive the car shakes. Once it warms up its stops shaking. Does anyone have any idea whats wrong?
the grinding at cold startup could be the beginning of a failing starter. the actuator might not be working properly on the starter causing it to not let go of the flywheel after releasing the key. mine did that for about 3 months before my starter finally gave out. you can replace the starter very easily and they're not all that expensive.
when you say shaking, is it just a vibration or is the whole car shaking?
i was thinking it was the starter its just a weird little grinding noise. It only does it when its cold out. I did a test on the battery and the alternator and they both checked out fine so i think that narrows it down to the starter ha....but when its a cold start and i start driving i feel the car shake like it stutters the first few times then its fine...do you think that could be the egr?
My car grinds by the belts for like 2 min. Mine and my cuzin 03 maxima do the same thing but my makes a worse nosie but its because of a bad precat car sounds bad and doesn't drive as smooth but I think its because my precat or muffler sytem . You u guys kno if by having a bad precat it can cause the car to shake and vibrate or even make the idle jump sometimes I really need to kno or can it be a bad tranny causing this vibration
If you researched this issue a little you would find that many many 5th gen owners have this problem on a cold startups, including myself. From what I have found, it has to either do with the PCV valve, or the timing chain tensioner. I have also been researching a problem where my engine is making a buzzing/rattling/grinding noise when driving at normal speeds (at around 1500-2500 RPMs). Does not make the sound when revving the engine in park or neutral, only when in gear. From what I understand, a lot of people have had this, and many say that getting the timing chain tensioner replaced fixes the problem. As far as your car shaking though, that could be a lot of things...
bc992164
Aug 26, 2015 12:19 PM
kirkhilles
Aug 8, 2015 10:53 AM
