whirling noise in the front
Old Oct 30, 2008 | 07:18 AM
zippyflu's Avatar
just bought a 2k max, and every time i turn the key, b4 i start it, there is this whirring noise in the front engine bay. I couldn't pinpoint the location of the sound. but the sound is very consistent, it whirls about 4/5 times.. then stops.. it whirls be4 i start the engine and while i have the car in park, i think it whirls while i have it in drive too. It is a very consistent whirl/humming..
(sounds like something is spinning..whirling) (like a battery powered screwdriver)
any ideas?
thanks in advance
(btw bought the 2kmax for $2k.. 105k miles, car would stall at stop signs and redlights, so i just changed the MAF and its fine for now. Cant really take it out on the road until i get my plates which will be done in a few hours.)
Old Oct 30, 2008 | 07:58 AM
pmohr's Avatar
No more Maximas...
any ideas?
thanks in advance
Sure it's from the engine bay? The fuel pump sounds similar to your description.
Old Oct 30, 2008 | 08:41 AM
Justaguy's Avatar
Funny...I have the same problem from my 1997 maxima.
It occurs more when I am driving and I hear this grilling sound for 3-5 seconds then it stops for about 4 minutes and does it again. It sounds like an electric screwdriver. It is coming from the engine bay...I'd take a guess that the noise is coming from the right side..
I'm thinking it could be some temperature gauge or something like that.
Old Oct 30, 2008 | 09:12 AM
kdarcangelis870's Avatar
Its probably the electric motor mounts that are making the whirring noise. My 2000 GLE does the same thing when I turn the key to on.
Old Oct 30, 2008 | 10:28 AM
Justaguy's Avatar
Yes it is.
Found this site:
http://forums.maxima.org/5th-generat...sy-change.html
So no harm in leaving it as is?
Old Oct 30, 2008 | 10:54 AM
Tcrast1's Avatar
disconnect the wire harness for both motor mounts. you can mess up the ECM if you dont.
Old Oct 31, 2008 | 04:25 PM
zippyflu's Avatar
well i talked to my mechanic, he says its the fuel pump....but ill work on it this weekend.. the motor mount sounds like the first thing ill do
Old Oct 31, 2008 | 05:55 PM
tav303's Avatar
radiator fans? they whirl
adamgalazka
Feb 5, 2023 08:24 AM
wyobbagy
Jan 3, 2023 12:03 PM
GregL65
Sep 5, 2015 09:37 PM
jfl330
Sep 4, 2015 01:44 PM
