Need Help Install Of PR Cai!!! Please!!
Old Nov 12, 2001 | 05:36 AM
PCGuRu2K's Avatar
Hi Guys...
I got the hole drilled and everything popped the tube in the whole. Just as I thought I had got it in properly, I could line up the battery tray nor the fuse box. I used the template from
The Max Anyone have any ideas?
Old Nov 12, 2001 | 06:03 AM
Chris91SE's Avatar
Eagles Fan 4 Lyfe
Re: Need Help Install Of PR Cai!!! Please!!
Originally posted by PCGuRu2K
Hi Guys...
everything should just fall back into place...are you sure the hole is correctly drilled...i don't mean to question you but people have emailed me with the same problem and the hole was incorrectly drilled...
Old Nov 12, 2001 | 06:11 AM
Dustyroads's Avatar
This ia a white cover on the bottom of the fuse box. YOu need to remove that thing and then the fuse box will fit. I don't think I had any troubles with my battery tray not going back in place. Just make sure to remove the bottom cover of the fuse box and you should be all set! Good luck!
Old Nov 12, 2001 | 06:12 AM
PCGuRu2K's Avatar
Re: Re: Need Help Install Of PR Cai!!! Please!!
Using the template.. You align the hole to the top hole from the battery tray hole right?
Old Nov 12, 2001 | 09:13 AM
a33's Avatar
a33
the only thing that didnt fit was the white cover at the bottom of the fuse box.......
but after removing the white cover, i noticed all the wires hanging... and i didnt like that, i just didnt think it was safe, so i cut the white plastic at an angle so that it would cover the wires and fit the pipe
for those that still have the white cover, i reccomend that....
Old Nov 12, 2001 | 10:29 AM
Dario's Avatar
what did you use too cut the hole out and was it a clean cut or kind of rough???
Old Nov 12, 2001 | 12:45 PM
PCGuRu2K's Avatar
I used a 3" Dremmel tool. It's pretty much a perfect circle. The battery tray cannot line up with the holes because the pipe is in the way. Unless I need to drill the hole more to the right?
MaxLife17
Jun 27, 2019 01:37 PM
Excalibur23
Oct 13, 2015 04:33 PM
2kmaximel
Sep 16, 2015 03:19 PM
A32goldylocks
Sep 16, 2015 01:33 PM
Johnny9595
Sep 3, 2015 05:18 AM
