Recirculation button on Climate Control not working
Old Nov 22, 2008 | 05:48 PM
Metal Maxima's Avatar
SHIFT_om nom nom nom
Old question, nerver was answered, IIRC, but I'll ask anyway
Recirc button on my Climate control is not allowing outside vents to close, anyone ever figure out how to resolve this?
Old Nov 22, 2008 | 06:00 PM
maximase86's Avatar
I love lamp.
Have you tried running the diagnostics on it? The steps are in the FSM.
S
Old Nov 22, 2008 | 07:20 PM
S
Dammit, I was hoping I would not have to resort to that. OK, time to hit the books. I'll post on my findings.
Old Nov 22, 2008 | 07:31 PM
jasonmax's Avatar
can you feel the change of wind noise when you hit the button? I might be just a LED light.
Old Nov 22, 2008 | 07:34 PM
Nah, I wish. No pressure change = inlets are not closing.
Old Nov 22, 2008 | 10:08 PM
Ok, looks like I'm going to need a multimeter and some time with harnesses M83 & M57. I'll have to get to this some time during the week. Step I is done...
Old Nov 23, 2008 | 12:05 AM
The Law's Avatar
I R The Law
Sounds like fun!
Old Nov 23, 2008 | 05:53 AM
Yeah, it's going to be a treat, although I am going to be happy to have a write-up to help out other members at the least.
Old Sep 26, 2009 | 08:08 AM
J-Rod's Avatar
Metal... did you ever find time to do that write up bro??? Mine is doing the same thing. Found your thread during a search, and you so abruptly ended it without the write up. Just wondering what your fix was.
thanks,
Old Sep 27, 2009 | 08:31 AM
J-Rod's Avatar
ttt
anybody?
Old Sep 28, 2009 | 06:16 AM
J-Rod's Avatar
METAL waaaaasssssuuuuppppp
Old Sep 28, 2009 | 06:31 AM
For whatever reason, the button wears out over time. Replace climate control module and you should be good to go. Thhis solved my problem, I can help you troubleshoot if this does not fix the issue.
Old Sep 28, 2009 | 08:48 AM
J-Rod's Avatar
You da man!!! I'm going to give that a go, and report back. Thanks.
IDK if it matters but my light on the button still will come on, just not hearing the "flaps" move and the air current pick up like it did when it was working, is that what yours was doing? Mine is the automatic climate control.
Old Sep 28, 2009 | 08:55 AM
Same exact symptoms.
Old Sep 29, 2009 | 05:07 AM
Professor's Avatar
Air blend door stepper motor maybe faulty.
Old Sep 29, 2009 | 08:11 AM
J-Rod's Avatar
You know.... towards the end there I could here the "flapper" or the door more-so than before. Is it up under the dash, and/or easy accessable? You might be right.
Metal
It looks like the control module is going to be a dealer only thing, you remember how much you paid, by chance?
Again thanks.
Old Sep 29, 2009 | 08:23 AM
fflint_18's Avatar
OK, I am going to ask a dumb question. My recirc light only lights when I am using the main A/C vents.
Is this how it should be??
When I run the A/C on defrost to clear the windshield, I'd like to be in recirc.
Old Sep 29, 2009 | 10:33 AM
J-Rod's Avatar
Is this how it should be?? Yes
When I run the A/C on defrost to clear the windshield, I'd like to be in recirc. Can't do that, the system uses the same duct work to recir the air; that system uses to defrost the windshield
answers in red
Old Sep 29, 2009 | 10:44 AM
djfrestyl's Avatar
Suspension Yoda
Originally Posted by J-Rod
Metal
I'd go with junkyard or parts car off the forum first - that will likely be a very expensive part from the dealer.
Old Sep 29, 2009 | 02:46 PM
IIRC, you have to remove the glovebox and passenger airbag to view it...or the center console...but you can view it without removing the dash...
Metal
$25 on eBay. They are a dime a dozen nowadays. Sit tight until you can get one for under $40 from there.
Old Nov 6, 2011 | 07:41 AM
jkmay01's Avatar
Lil 8
Hey metal sorry to chime in on the older thread, but I too am having the same problem, I can't control the vents from upper to feat. When I press the mode button you would normally hear the flaps open and close,but no more. I have taken the blower off, which does work. And see both flaps in a open position. So at this point despite changing the temperature I get only cold air at the feet. Another strange find is I park my car in a heated garage so it's about 70 in the winter, when I press the amb temp button it shows -22 degrees? I am off to borrow a friends code reader to see if any codes getting produced. I am looking at the climate control module gone bad? Any thoughts? Sorry about jumping in a little off topic
Old Nov 7, 2011 | 05:00 AM
djfrestyl's Avatar
Suspension Yoda
Doubt you'll get any results from the code reader.
It may be the temperature sensor too....
Old Nov 7, 2011 | 07:49 AM
jkmay01's Avatar
Lil 8
Yes, I didn't get codes all pass, so just ordered another heat/ac module from eBay. Funny enough now getting blinking airbag led? Lol when it rains it pours! Thanks for input
MikesChevelle
Mar 2, 2021 11:32 AM
dr3am
25
Oct 22, 2015 08:53 PM
asianstyle
Aug 24, 2015 08:29 PM
