Would i rub?
Old Dec 8, 2008 | 08:06 PM
Ahmad_1290's Avatar
Would i rub?
I just picked up some g35c 18's with 225/45/18 all around. Do you any of you know if i would rub with H-techs? also what drop do you recommend with those wheels. I'm planning on using stock struts for a while and I've heard that progress is the lowest i can go on stocks. Thanks in advance
Old Dec 9, 2008 | 07:04 AM
choiiiiiiiiiii's Avatar
i dont know how low the htech drop is, but with the z wheels with the same tire specs and with stechs, i rubbed. you're gonna wanna roll the fenders
Old Dec 9, 2008 | 10:42 AM
Drockb418's Avatar
i have g35 wheels with 255/35/18 and i have no problems
Old Dec 9, 2008 | 03:27 PM
dnozzle2789's Avatar
i think that if my 20x8.5 wheels with 225's dont rub EVER, i think youd be fine. more than okay
Old Dec 9, 2008 | 04:06 PM
Orgullo's Avatar
$$ Ballin on a Budget $$
Your sidewall on the tires are too big. Go with a different size. ie... 235/35/18 and you'll be good.
/thread
Old Dec 9, 2008 | 05:27 PM
Ahmad_1290's Avatar
So what drop would be good with these tires?
Old Dec 9, 2008 | 06:38 PM
because you have 35 profile tires
dnozzle2789-i think that if my 20x8.5 wheels with 225's dont rub EVER, i think youd be fine. more than okay
you don't rub because your offset is probably not like g35 rims.
Old Dec 9, 2008 | 06:39 PM
i have tein-s and had the 350z rims which probably has the same offesett as the g rims...after rolling the fenders, i didn't rub. no problem
Old Dec 9, 2008 | 06:43 PM
IHAVEA2KMAXIMA's Avatar
It depends on the offset.
35 is a little too low profile. 45 is a bit big, but it gives better cushioning.
Old Dec 9, 2008 | 07:13 PM
CoolMax's Avatar
is invisible
http://forums.maxima.org/tires-wheel...s-maximas.html
Old Dec 9, 2008 | 11:49 PM
Choii -
tis true but i dont know what the offset of those rims are...i would guess 35? it was a "act before thinking comment"
Old Dec 10, 2008 | 12:09 AM
they are +30.
Old Dec 10, 2008 | 12:13 AM
well now i wanna delete my post :-)
Old Dec 10, 2008 | 06:53 AM
Choii -
Old Dec 10, 2008 | 01:04 PM
reeloop's Avatar
I'm running 245/45/18 , it raised my car quite a bit comparing to the stock wheels which are smaller in overall diameter ( im on progress springs and tokico blues ) I will go with 245/40/18 next time I buy tires. You learn something new everyday Either that or go with even shorter springs.
I don't think you will rub because you have 225 versus my 245, which does affect things alot, the tire will be further from the fender, and it will be a lil more than half an inch smaller in diameter.
If you do rub, the first spot will probably be passenger rear because of the shifted beam. ( once you lower the car ).
It's all in the offset! too bad I don't know mine
Old Dec 10, 2008 | 01:05 PM
No rub, no love.
Serotta33
Sep 17, 2015 12:14 PM
thenewguyy
Sep 12, 2015 11:12 AM
MikesChevelle
Aug 7, 2015 05:57 PM
RealityCheck
Aug 5, 2015 06:18 AM
Bucktown
Mar 20, 2001 06:18 PM
