Timming chain
Old Dec 15, 2008 | 01:56 PM
Lontar1's Avatar
Puerto Rico-Maxima Lover
Timming chain
has anyone replaced their timming chain and:
How many chains are in this engine? Nissan says 3, etc etc......
Old Dec 15, 2008 | 03:19 PM
jasonmax's Avatar
timing chains don't need to be replaced in our cars unless there's something broken.
theres only one.
Old Dec 15, 2008 | 05:42 PM
02MAXZIMA's Avatar
theres only one.
there are three chains. one main one that runs from the crank then to cylinder head. then there 2 secondary chains one on each cylinder head running the cams.
Old Dec 15, 2008 | 07:10 PM
jasonmax's Avatar
arent they on the same one chain?
Old Dec 15, 2008 | 07:19 PM
SoulEater's Avatar
nope, they have different sizes
Old Dec 15, 2008 | 08:04 PM
supraken's Avatar
The timing chain itself doesn't need to be replaced, but doesn't the tensioners need to be replaced?
Old Dec 15, 2008 | 08:19 PM
tbergma1's Avatar
You mean tensioner, if it is worn out, yes. Should be in the stickies.
Old Dec 19, 2008 | 07:31 AM
NmexMAX's Avatar
dot dot dot ...
3 chains w/ associated tensioners:
Old Dec 21, 2008 | 12:36 PM
ghostrider17's Avatar
Nice Pic Nmex~!
At 68k miles, I'm a LONG-WAY from needing to replace my T-chains, but out of curiosity (since I will NOT be doing this by myself) how much does this open-heart surgery cost??
I've lived thru timing-belt replacements in hondas and toyotas, but never a CHAIN in a Maxima!
thks,
gr
Old Dec 21, 2008 | 12:44 PM
AceofSpds's Avatar
wat
No need to change the chain unless it snapped.
Originally Posted by ghostrider17
Nice Pic Nmex~!
thks,
gr
Probably a good bit, you pretty much have to pull the motor to do this.
Old Dec 21, 2008 | 01:13 PM
quiksilver20004's Avatar
might be a dumb question but do these chains get run through the crank case oil or anything along those lines??
Old Dec 27, 2008 | 10:16 AM
FanaticMadMax's Avatar
Timing chain and belt works the same way, the difference, Chain should last the life of the car, unless you're not maintining the car with the maintance. The Belt are run by rubber belt, they do need routine replacement at least every 60k miles. Chain are usually the best to have, thus lowest cost of ownership with the engine rather than replacing belts such as Honda, Toyota. Lately a lot of manufacture are switching back chain, such examples like Subaru, I had one, they were run on belt, til recently they went back to chain, since it's a pain in the butt to replace on a boxer engine.
Old Dec 27, 2008 | 01:25 PM
rroderiques77's Avatar
Demodded and Forgotten
Nice Pic Nmex~!
thks,
gr
Book time calls for 11.5 hrs
Old Dec 27, 2008 | 09:54 PM
scmax2000's Avatar
Nice Pic Nmex~!
thks,
gr
I had one of the chains was stretched, but I replaced the whole set(3 chains, sprockets,& tensioners),you can find the set for Approx. $250.00 & the labor is about $700.00 to $850.00.(The Engine will not be pulled out).
note: If one chain or tensioner is bad it will be a good Idea to replace the full set because the labor will be the same).
Old Dec 28, 2008 | 03:48 AM
CMax03's Avatar
Are you sure that's your problem? All I can tell you is get the same one the factory carry's if you can find the same exact p/n elsewhere for less, get it. But I trust in those Nissan timing chains!!!! I bought an aftermarket Cloyes timing chain set for my D21 Hardbody... Well the factory original was still in good shape @ 272,000 miles, but I was doing a rebuild so I replaced with a good well known U.S. brand(Cloyes). New tensioner, guides, sprockets, and chain. Well once on the road and the engine was broke in I enjoyed taking this truck back and forth to Louisiana and going fishing out in the boondocks...I was coming thru Winnie on I10 running hard with a Mustang and 2 Hondas @ about 125 mph. When reached home in Houston I noticed an loping idle and something was wrong. Well I got about 55,000 miles out of the Cloyes brand and I regret need going with the real deal (Oem Nissan) from the very beginning. Installing an Oem timing kit would be the best thing if the chain is the problem, but,.... I would check out those tensioners first cause more than likely that's the culprit Good luck.
Old Dec 28, 2008 | 04:03 PM
16blkmax's Avatar
so u never need to replace these not even with 150k miles??
Old Dec 28, 2008 | 05:01 PM
pmohr's Avatar
No more Maximas...
Not even with (insert number here) miles. When they said the life of the engine, that doesn't mean that at 150k they magically die.
Old Dec 29, 2008 | 12:11 PM
Lontar1's Avatar
Then I guess I won't have to replace them. i always thought that they were supposed to be changed, but will see. Thanks to all.
Old Jan 4, 2009 | 11:15 AM
hoppers69's Avatar
Yeah great pic! Where is the dreaded TC tensioner anyway, is it that dark brown/maroon box on the middle right side on the chain?
Sorry if its obvious, just never saw this pic of the 3.5 before.
Old Jan 4, 2009 | 11:20 AM
pmohr's Avatar
No more Maximas...
No, that's just another guide. Here:
gustavison
Oct 4, 2015 06:50 PM
kjlouis
Oct 3, 2015 05:29 AM
JoshG
51
Sep 21, 2015 10:41 PM
jerrod99_se-l
Sep 16, 2015 02:39 AM
NissanNismoZ
Sep 12, 2015 07:30 AM
