I would like to know reviews for the Vias block off and the intake spacer.
Old Jan 6, 2009 | 02:57 PM
perkman87's Avatar
Hey guys and gals.
I have read lots about the vias block off
I know the vq35 will loose low end, and the believe the intake spacer will adjust this, am I correct?
Also I have a auto.
Please give me a brief description,
Thanks, Perkman87
Old Jan 6, 2009 | 02:58 PM
pmohr's Avatar
No more Maximas...
Did you search around? There have been a few reviews already posted on the org.
Old Jan 6, 2009 | 03:00 PM
perkman87's Avatar
Yes, but I want to know how people like it after installing it.
De they miss the low end torque, and any problems.
I found mixed reviews, so i Figured I would clear it up for everyone.
Old Jan 6, 2009 | 03:32 PM
MIK3's Avatar
The lost low end is nothing compared to the gained and consistent high end with just the block plate. Getting the spacers installed next week or so. I'd vouch to say it's close to the best $60 bucks I spent (bought it a while ago). No complaints.
Have you looked at the dynos?
Old Jan 6, 2009 | 03:37 PM
perkman87's Avatar
Yes They do look consistant,
I was just gauging interest on the combo.
But you def feel a big diff up top Huh?
Old Jan 6, 2009 | 03:55 PM
kcxd35's Avatar
Since search isn't working for me, basically the blockoff plate will enable the VAIS to be open all the time instead of at 4k???
Old Jan 6, 2009 | 04:01 PM
MIK3's Avatar
Your'e half way right. There will be no VAIS when you install your blockplate. The only part of the VIAS that will remain is your gasket to be used when installing the block plate. You remove the VAIS in order to install the block plate. This, in return, means that there is no variance in the amount of air the intake system consumes, hence the V in VAIS. It'll act as if your valve would be constantly open. The back-pressure created from when the valve was closed pre-3800rpm is what created the increase in low-end when the VAIS is installed.
Old Jan 6, 2009 | 04:02 PM
perkman87's Avatar
That Is what I think happens, I believe you can gut it or leave it intact. but It causes the VIAS to no longer open just at 4k, but all the time.
Old Jan 6, 2009 | 04:08 PM
kcxd35's Avatar
No cel or anything??? and isn't it better to have that feature as the low end torque will help you get up to speed quicker and then the valve open up for more HP???
Old Jan 6, 2009 | 04:12 PM
perkman87's Avatar
Im guessing that once the pressure builds up in the empty Manifold it produces more power, and flows better. I wish I could find the graph, but Im in the same boat as you I am debating on doing it.
Old Jan 6, 2009 | 04:53 PM
nismowolfe's Avatar
I just did this this weekend I dont have the block off plate yet but I removed the valve and the rod the valve was bolted to and plugged the hole shut and removed vacumm canister. I noticed the small loss in low end but the top end was awesome and it sounds mean as hell. I have only did a couple 70mph to 100mph runs because weather is bad right now but pulled very hard and I also have a auto.
Old Jan 6, 2009 | 05:26 PM
johnnyd2k2's Avatar
I have had the block plate and SSIM for a while and love them both I recently added the spacers and it seems I regained a lot of the low end loss from both the SSIM and vias removal my butt dyno isn't great and I've gotten used to the low end loss but can deffinatly feel some gains with the spacers. So if you are plannin on gettin the spacers too I wouldn't really worry about the loss cuz it is minimal compared to the gains.
Old Jan 6, 2009 | 05:37 PM
kcxd35's Avatar
How's the fuel economy with the block-off plate better or worse or the same???
Old Jan 6, 2009 | 05:38 PM
knight_yyz's Avatar
Toolie
the NWP spacers is an excellent mod for the money. You won't regret it. Excellent mid range power and torque gains
Old Jan 6, 2009 | 05:41 PM
kcxd35's Avatar
Also this is interesting...
http://www.nissanclub.com/forums/eng...-vs-stock.html
Old Jan 6, 2009 | 06:03 PM
perkman87's Avatar
Lots of good info Guys. I am think I will do this next week, just wondering if anyone has a n actual write up?
and the spacers will be done at the same time so lets see!!
Old Jan 6, 2009 | 06:06 PM
kcxd35's Avatar
It's on the nwp website, there's a pdf instructions next to item....
Old Jan 6, 2009 | 06:09 PM
perkman87's Avatar
Pffft.... Smarty Pants.
Thanx mang!
Old Jan 6, 2009 | 08:03 PM
perkman87's Avatar
Thanx Mang!
Old Jan 6, 2009 | 08:05 PM
perkman87's Avatar
Yes Very interested in this? Not that i would care about 2-3 mpg since I already get like 17 city
Old Jan 6, 2009 | 09:04 PM
Scottwax's Avatar
That's Mr. Detail to you
Interested in this too. I guess a lot of the time it depends on how much you use the new found power.
Since the dyno graph linked for the VAIS block-off plate shows the power loss to be between 2800-3800, that is higher than my typical freeway speeds (72 is 2500 rpm) so my assumption would be no change in steady freeway speeds unless you are at 2800 rpm or higher due to the slight power loss meaning you'd step on the gas a bit harder to maintain your speed.
Someone else mentioned the gains above 3800 rpm are worth the loss between 2800-3800. Do the rest of y'all who have done this believe the same? How many of you have automatics and does this negatively affect around town driving throttle response?
Seriously considering the block off plate due to the big gains above 3800 rpms at such a low cost. Just want to be sure that midrange drivability isn't affected too much since it might be a little while before I change plugs and do the intake spacers.
Old Jan 7, 2009 | 04:19 AM
johnnyd2k2's Avatar
With both spacers and the block plate I didn't notice any drops in my MPGs in the city but on the highway I seem to get a little better milage not much and I'm not totaly sure it was from the mods maybe 5% better.
Old Jan 7, 2009 | 06:09 AM
Renny017's Avatar
I'll be watching this too. Thinking of doing this in the near future.
Old Jan 7, 2009 | 06:18 AM
mist max2000's Avatar
have the block off plate.. its great..no idea about mpg.. the same? idk there are so many diff variables, driving style, other mods, winter temperatures and running open vs closed loop, tire size and weight,.. ect ect.....but i will be getting spacers in the future when i change my plugs..before sumer..
Old Jan 7, 2009 | 07:03 AM
rroderiques77's Avatar
Demodded and Forgotten
Keep in mind that tuning is important upon achieving that goal. Also, an extended rev limiter would be beneficial.
Old Jan 7, 2009 | 07:15 AM
perkman87's Avatar
the total hp If i am correct is a 20hp gain with both items installed. I beleive that for 220 for both It is a steal. Correct me if I am wrong.
Installing a y pipe could up the ante.
I mean for around 500
thats 30 hp???????
Old Jan 7, 2009 | 07:26 AM
perkman87's Avatar
Info On what the spacer does 10hp 12tq - But all cars are differnent
http://forums.maxima.org/group-deals...le-vq35de.html
Block off plate info
http://www.nissanclub.com/forums/eng...-today-17.html
This should help.
Old Jan 7, 2009 | 07:29 AM
Scottwax's Avatar
thats 30 hp???????
Doesn't always work that way. The intake spacer gains are mostly in the midrange, very little on top end. It also depends on the ability of the ECU to adjust for the increased airflow, and if it can't do it completely, you will get less gains than expected until you tune the engine on a dyno.
Old Jan 7, 2009 | 07:31 AM
perkman87's Avatar
Very true.
Old Jan 7, 2009 | 08:28 AM
HotshotVQ35's Avatar
y pipe on an 02+ isnt worth the money. i had one, went to headers. y is maybe 5-9 hp, for $350...
thats 30 hp???????
Old Jan 7, 2009 | 08:50 AM
MaximusMorpheus's Avatar
I am loving my SSIM and spacers since I got them done like 6 months ago. The sound from the exhaust and intake are different, lower tone plus it pulls like a raped ape on the highway...
Old Jan 7, 2009 | 10:36 AM
knight_yyz's Avatar
Toolie
i found the spacers added about 15-18 hp in my midrange, tuned with headers. Top end did not change, but I have not SSIM'd or removed the vias. YET. ssim is sitting on my basement floor waiting for the warmer weather.
Old Jan 7, 2009 | 12:33 PM
perkman87's Avatar
Are you an auto Knight, and if this mod causes midrange to improve, and the vias delete causes midrange to go down, I think they go hand in hand.
Also I believe the vias Delete will boost back up the loss in your 5K power bank
Thank you for the graph
Ah you are a manual. I figured it out!
Old May 24, 2009 | 11:07 AM
kcxd35's Avatar
Did the block plate and I just wanted to say that I feel no loss in low end torque, There might be on a dyno but i felt nothing and the top end is amazing... Def worth it...
mclasser
22
Nov 12, 2020 01:58 PM
howardis
Dec 11, 2019 06:10 PM
MichMaxFan
Sep 30, 2015 09:18 AM
King_Ten_Ahead
Sep 27, 2015 02:24 PM
rbaker100
Sep 25, 2015 07:52 PM
