ABS Light
Old Jan 25, 2009 | 01:34 PM
quiksilver20004's Avatar
ABS Light
I was messing around in the snow today doing ebrake slides and stuff and my ABS light came on and stayed on. I checked fuses and everything else that i could and found nothing wrong. I have an 01 maxima 5spd. Any ideas what it could be??
Old Jan 25, 2009 | 01:50 PM
BigOgre's Avatar
Sounds like fun.. got any vids..
Sorry I dont know what could be wrong..
Old Jan 25, 2009 | 02:22 PM
Blitzfist's Avatar
reset the ecu you probably threw the abs system into safe mode or something. its also possible(and likely) that you damaged the system.
Old Jan 25, 2009 | 04:01 PM
Yeah probably and im guessing it expensive to fix right?
Old Jan 25, 2009 | 05:14 PM
Blitzfist's Avatar
depends on whats wrong. reset the ecu before doing anything. if the light comes back on after that you know their is a problem
Old Jan 25, 2009 | 05:31 PM
PAREDLINE's Avatar
There is no such thing as ABS safe mode. You probably shorted out one of your ABS sensors and hopefully not your ABS computer. You need to do a scan with an ABS scan tool.
Old Jan 25, 2009 | 05:56 PM
Ah screw it i hate damn ABS anyways. Is there a way to be able to turn off the ABS dash light???
Old Jan 25, 2009 | 06:24 PM
bkmax96's Avatar
its more then likely just a sensor replace it and move along trust me
Old Jan 26, 2009 | 02:13 AM
ColdSHO's Avatar
i did the same thing and it just eventually went away, then years later i damaged a sensor while replacing studs, theyre sensitive, and its possible that just a small bend in one couse throw the code. i barely touched mine and it bent. im sure the weather dosnt help, mine are rusted to heck and back, and i only drove it during the winter a few years,now its a summer only car.
Old Jan 26, 2009 | 04:33 AM
Tippy Toes's Avatar
I have an 03 with the rear driver side abs light comes on, occasionally. I went in to the dealer and he said it was the sensor. As far as doing donuts in the snow..idk it could be a sensor or it could be something else. It's up to you to decide whether you want to fix the problem or not. I would take the advice of others and reset the ECU.
Any pictures of the donuts in the snow?
Old Jan 26, 2009 | 05:57 AM
Haha no sorry no pictures These cars are really fun to fake drift though. They slide and control really well
Old Jan 26, 2009 | 06:24 AM
bgod's Avatar
I had a similar issue last week in the snow. Wasn't messing around but the abs was kicking in a lot as there was a ton of ice on the ground everywhere.
At certain points the ABS light came on and the abs was disabled (could easily lock up the wheels). After a bit of driving and turning the car on/off it went away and abs worked like normal. No problems since.
Old Jan 26, 2009 | 03:55 PM
well i got in my car today and started driving and the light went off haha. I think i just had some snow or ice stuck down inbetween the sensor and ring
mvm062
Nov 30, 2020 09:00 AM
bbsitum
Sep 6, 2019 07:31 PM
Maxie40
Sep 14, 2015 11:28 AM
-ReLLiK-
Sep 8, 2015 12:02 PM
maximusrising
Sep 2, 2015 09:55 AM
