Auto dimming mirror wiring harness
Old Jan 27, 2009 | 07:57 PM
Progress's Avatar
It's business time.
Does anyone know that part number to the wiring harness to the OEM auto dimming mirror (w/o compass and thermometer)?
Old Jan 28, 2009 | 03:35 PM
pmohr's Avatar
No more Maximas...
The 4 or 5 pin connector? AFAIK that's a part of the room lamp harness. There are some universal harnesses online, check the manufacturer name on the mirror, then search for '$name wiring harness'.
Old Jan 28, 2009 | 06:01 PM
Progress's Avatar
It's business time.
Well it's off a 5.5 gen. I have no idea what the manufacture name is. I'll ask the seller. Thanks.
http://forums.maxima.org/5th-generat...ng-mirror.html
Old Jan 28, 2009 | 06:20 PM
Dust N Bones's Avatar
I believe the mirrors used on the 5.5 gens were made by Gentex.
Old Jan 28, 2009 | 06:40 PM
Progress's Avatar
It's business time.
Okay.
Something like this:
http://cgi.ebay.com/ebaymotors/Gente...QQcmdZViewItem
Old Jan 28, 2009 | 06:45 PM
VQP0WER's Avatar
Yup, Gentex got the market with these. Toyota's, Chevy, Nissan, etc.
Old Jan 28, 2009 | 07:09 PM
pmohr's Avatar
No more Maximas...
That's the wrong harness. That's a 10-pin, you need a 7.
http://cgi.ebay.com/ebaymotors/Wire-...spagenameZWDVW
http://cgi.ebay.com/ebaymotors/GENTE...spagenameZWDVW
Old Jan 28, 2009 | 07:10 PM
pmohr's Avatar
No more Maximas...
I see what you did there, in your sig
Old Jan 28, 2009 | 07:17 PM
Progress's Avatar
It's business time.
Cool, okay.
Now I looked at some of the write-ups and it seems everyone wires the mirror up into the ceiling, down the A-pillar and down to the fusebox. Is that what I will have to do or could I just splice the wires into the maplight?
If not, I'll have to get some wire to make it run all the way down the A-pillar.
Old Jan 28, 2009 | 07:18 PM
pmohr's Avatar
No more Maximas...
Cool, okay.
There's a constant B+ to the map light, so you could hook it up there, but it could very well drain the battery. Do you have a sunroof?
Old Jan 29, 2009 | 12:25 PM
Progress's Avatar
It's business time.
I do have a sunroof.
Old Jan 29, 2009 | 01:16 PM
pmohr's Avatar
No more Maximas...
Wire it up to the sunroof power supply then, since that's switched.
Old Jan 29, 2009 | 01:21 PM
Progress's Avatar
It's business time.
Okay, do you know which wires need to be connected? Will it just be positive and negative or will I have to ground one, too?
Old Jan 29, 2009 | 01:26 PM
pmohr's Avatar
No more Maximas...
There'll be a power and a ground, at the sunroof switch it should be red and black wires, respectively.
Old Jan 29, 2009 | 01:36 PM
Progress's Avatar
It's business time.
Okay, great! Thanks, you've been a lot of help.
Old Jan 29, 2009 | 05:56 PM
nabeel24's Avatar
Nice needed to know how to do this as well. just bought one.
Old Jan 29, 2009 | 06:29 PM
VQP0WER's Avatar
Old Feb 26, 2009 | 09:07 AM
Progress's Avatar
It's business time.
I have a problem. For some reason the mirror is not dimming. I bought the harness and plugged it into the back of the mirror. I spliced the red wire of the harness to the red wire of the sunroof. I spliced the black AND green wires from the harness to the black wire of the sunroof (per the instructions given with the harness). Still, the dimming function is not working and I have no idea why?
Any ideas?
Old Feb 26, 2009 | 09:37 AM
AEMAXIMA01's Avatar
Quick question: I already have a dimming mirror in my 01, so if I were to get a dimming/compass mirror, would I have to buy a new wiring harness, or will the one that's already there suffice?
Any ideas?
Maybe a bad mirror?
Old Mar 4, 2009 | 02:38 PM
Progress's Avatar
It's business time.
Anyone have an auto-dimming mirror with 35% tint? If so, do you have any dysfunction in your mirror dimming?
Old Mar 4, 2009 | 03:36 PM
maximase86's Avatar
I love lamp.
I have 15% tint and my mirror seem to dim like it used to. It will, when someone has lights that are angled just right at the sensor.
Old Jun 20, 2009 | 09:34 AM
Progress's Avatar
It's business time.
When the mirror is correctly installed, is there a light on it that actually indicates whether it is working?
Old Sep 21, 2009 | 12:51 PM
Progress's Avatar
It's business time.
This is driving me crazy
After having the the mirror on for nearly four months and not having a dimmer I'm fed up.
I took apart the quick splices and found that they had barely scathed the wires going to the mirror because they are such a small diameter.
To fix this, I decided to solder the wires together, with success. Here is a picture of red wire from mirror to red wire of sunroof. Then the black wire and green wire go to the black wire of sunroof which I assume is ground. Solders were clean, checked the continuity and it was good before I put the liquid insulation on (which you can see in the picture).
I plugged it in an turned the car on and no dice. I didn't receive an answer of whether a light turns on on the mirror but if it does, it didn't for me. I tested the auto dim and that didn't work either. I've tried two different mirrors with no luck.
What is going on here? BTW, sunroof works fine so I didn't mess anything there up.
Old Sep 21, 2009 | 02:27 PM
VQP0WER's Avatar
Have you tested for power at your connections? Green wire from the sunroof motor is not ground, it's 12v. Ground will be black.
EDIT: Maybe I'm not reading the diagram correctly, but the red wire to the sunroof motor is for the switch. If you push the button to open the moonroof, does the mirror turn on?
Old Sep 21, 2009 | 03:14 PM
Progress's Avatar
It's business time.
I checked it again and I guess I couldn't find a straight power directly from the switch. I changed my plans. I soldered on longer wire (benched tested it and finally made sure it worked - the light lit up!) and am going to run it down the A-Pillar to the cigarette lighter lead.
I use a circuit tester to the connector going to the sunroof. Instead of lighting up at any of the pins, it actually activated the sunroof. One pinned, open, the other closed, one tilted, the other un-tilted and the other two did nothing.
Thanks for the help, though. Once I run the wires I'm sure I'll be GTG.
EDIT: BTW, in the picture, you're seeing the black and green wires from the mirror soldered to the BLACK ground wire of the sunroof switch and the red wire to the red wire in the switch.
The Frye
Sep 2, 2021 11:03 AM
9aj9
Apr 5, 2020 12:11 AM
Kingofmaximas24
Nov 12, 2015 04:40 PM
