RPM's
It all depends on your tire size.
With stock tires you should be doing ~2750 in 5th with the stock 17s. With an A33B 6MT in 6th it'd be ~2300.
Is there a problem you think you have, why did you make this thread?
pmohr generally does not comment unless he knows what he is talking about. You should do less
and more listening.
Not true. Typically more gears means closer ratios and less gears means further ratios, notwithstanding the highest gear's ratio. In fact, correct me if I'm wrong, but most AT cars cruise at a lower RPM in 4th on the highway than their MT counterparts do in 5th.
Yes 4ATs rev lower than the 5 speeds...however the 6-speeds have a double overdrive and because of this, even with the longer gearing of the auto, it revs lower. The 4ATs have very long 3rd and 4th gears, which is why they rev lower...
I'm so sorry to confuse you... Well...the speedo doesn't know what tire you occur to put on. It calculates the speed according to the driveshaft RPM. Yes, the REAL speed does change (the smaller the tire, the slower), but we can't see it on the instrumental panel. Also, any given gear/engine RPM produces strictly determined number on a speedo table and can't be changed (unless the clutch is slipping).This is because of direct mechanical connection between the components (we are talking about MT)
We don't have a driveshaft....nice try on the googling work, though. Yes tire size will affect the speed on the instrument panel. A smaller tire will read higher on the spedometer than you are actually traveling, and vise versa
so then why is my car reving so high at highway speeds. Im generally at 2.5 rpms at 70mph. is that normal? I just put it in D for highway driving(and all driving for that matter). correct me if im doing anythign wrong
2. You forgot to say, the engine RPM will be accordingly higher, too, comparing to the stock tires.
We don't have a drive shaft. We have two axles, that's all. It's all semantics, but if on a RWD vehicle you call the two shafts which deliver power from the diff to the wheels axles, why would it change at all in a FWD vehicle?
Same exact thing, different packaging.
For determining adapter requirements when one is used, the formula is:
(1000) (Ratio of Speedometer Driven to Drive Gear) divided by:
(Tire revolutions Per Mile) (Rear axle ratio) = Speedo adapter ratio
Adjustable electronic speedometers usually use dip switches to adjust for variables, manufactures such as Ametek have a downloadable program that just has you enter the same information and it tells you which switches to adjust.
For the most accurate adjustment of a speedometer, tire revolutions per mile must be used, not tire size, as this can vary by manufacture. We don't really care about this in a passenger car, but in the transportation industry, they rely on accurate milage to get paid properly.
Thanks for dumbing it down for me, but figuring out speedo ratios is something I do on at least a weekly basis as part of my daily job.
half shaft or axle would have been a better term...but see mtrai's post above: the speed sensor is inside the transmission.
Now we're getting somewhere!
Unclejunebug
Apr 2, 2016 05:42 AM
ef9
Oct 4, 2015 08:43 AM
Need help
23
Oct 2, 2015 08:56 AM
