Bad Coil Diagnosis
Old Feb 1, 2009 | 10:04 AM
wyche89's Avatar
Bad Coil Diagnosis
Hey guys. Well, after putting headers on my car and throwing off my A/F ratio for a while, I got the good old P0300 (random cylinder misfire), and I suspect it might be one of my coils. I saw this in another thread, and wanted to ask about it. Is this an accurate/safe way of isolating which coil is bad?:
"I suggest you take off the spark plug cover and unplug those coils one by one and see if the idle changes. Then do the same for the rear coils. This will tell you which coil is bad."
Old Feb 1, 2009 | 10:06 AM
hotstartup's Avatar
sounds right. lots of threads on this.
Old Feb 1, 2009 | 10:39 AM
wyche89's Avatar
yeah, i know but i only saw this procedure in 1 of them, and i just wanted to make sure it was:
1: safe to do
2: an accurate way to tell which coil is bad
Old Feb 1, 2009 | 11:55 AM
pmohr's Avatar
No more Maximas...
Yes, that's all you need to do. That just narrows it down to a cylinder, doesn't necessarily mean it's the coil.
Also that procedure has been posted countless times on the org, more than enough for you to have confirmed; probably a good 20 times by myself at least.
Old Feb 1, 2009 | 12:26 PM
boris's Avatar
This will work if you get the continuous misfire, i.e. one (or more) cylinder's not working. In some old thread the guy claims, if you pull the code before the SES starts emitting light, you have a good chance to narrow the problem (i.e. get the code about specific cylinder).
Old Feb 1, 2009 | 03:40 PM
wyche89's Avatar
well, i got the car scanned 3 times since i put my headers on... the first time i got it scanned, the misfire code came up.. the second time the misfire code did not come up.. and the 3rd time the code came up again.. so that means it's intermittent i guess? what exactly does that say about the problem?
Old Feb 1, 2009 | 03:43 PM
wyche89's Avatar
my bad, i havent seen those posts.. so if i narrow it down to a specific cylinder, that means it could be:
1. coil
2. spark plug
3. injector
anything other possibilities?
Old Feb 1, 2009 | 05:25 PM
jdm0830's Avatar
just shining in, MAF? i didnt know it was linked to my entire car's codes.
Juan
Old Feb 2, 2009 | 08:18 AM
REPOMAN2K9's Avatar
my 2000 maxima has the same problem an intermittent misfire on cylinder no 4
me and nissan changed all coils plugs and i still get the problem every once in a while
my code is 1320 primary ignition i dont get it the first cause on the lists is coils
Old Feb 2, 2009 | 08:22 AM
pmohr's Avatar
No more Maximas...
Actually, the first cause on the list is harness or connectors. The code can also be thrown because of the CKPS REF, if you read the list.
Check continuity on the harness, and check the CKPS.
Old Feb 2, 2009 | 08:26 AM
ghostrider17's Avatar
just an offhand guess:
Did you have the recall done for the Crankshaft position sensor??
I think there was another recall for a similar engine sensor as well....
Prob. not it....but just thinking outloud.
Is it stumbling or misfiring? I've had odd-ball SES lights come and go, sometimes without doing anything more than unplugging the battery, or resealing the gascap.
I can't WAIT for my coils to start going bad.
I have 3 months and 8k left on my extended warranty....then it's all down hill from there!!
gr
Old Feb 2, 2009 | 09:12 AM
wyche89's Avatar
gr
no, i havent had that recall done
Old Feb 2, 2009 | 09:13 AM
wyche89's Avatar
1. coil
2. spark plug
3. injector
anybody?
Old Feb 2, 2009 | 09:35 AM
max2001's Avatar
I wonder if you could get a performance coil that would be better????
Old Feb 2, 2009 | 09:37 AM
pmohr's Avatar
No more Maximas...
anybody?
If it's misfiring, it could be those three, or it could be an internal problem. Those three are the most likely, though.
pmohr's Avatar
No more Maximas...
There's no point, really. Stock ignition is capable of more power than you're ever going to make.
Old Feb 2, 2009 | 10:05 AM
knight_yyz's Avatar
Toolie
I was getting the random misfire code a while back so I bought 6 coils and replaced them. Problem didn't go away. It didn't happen often but it was enough to annoy me as to why. Then I got my phenolic spacers and the problem went away. So i wonder if I had a tiny leak in the intake manifold gasket somewhere causing the one cylinder to run too lean and cause a misfire.
Old Feb 3, 2009 | 07:57 AM
REPOMAN2K9's Avatar
which harness to da coil ecu input or crank pos sensor
Old Feb 3, 2009 | 08:01 AM
pmohr's Avatar
No more Maximas...
Look at the FSM, you'll see.
Coil harness, and CKPS REF (not POS) sensor/harness.
Old Feb 6, 2009 | 03:52 AM
onewheelf4's Avatar
Yes, thats the correct way to do a simple power balance test. If you find out which cylinder is not firingl=. Just swap it with a good coil from another cylnder on the engine and listen for rpm change. If thats it, your good to go and back on the road. good luck
TallTom
57
Oct 14, 2025 05:16 PM
jmlee44
Oct 2, 2022 02:13 PM
chisam14
Nov 6, 2018 08:56 PM
Andy29
Sep 29, 2015 05:32 AM
zmcneely13
Sep 26, 2015 02:26 PM
