Side Marker Rewire Problem
I attempted to rewire the side markers using the instructions on the 5thgenmaxima site. But I could not find the 3M Wire Taps so I bought some taps that splice into the wire. After I was done, I turned them on and the fuse blew. Could this be due to the tap I bought, a cheap fuse or something else? I would like to make another attempt but my wife really doesn't want me touching the car anymore because of this. She said I should stick to programming. Any ideas?
Originally posted by Y2KevSE
You forgot to cut the ground wires for the sidemarkers.
Dixit
http://www.geocities.com/amixam69/nissan/siderewire/
Re: http://www.geocities.com/amixam69/nissan/siderewire/
rear corners.......?
Originally posted by ChillWill2000
Thank You for the info....sooo easy now.
matt
Anyone know about a rewire for the 02? I did it on my 00 and loved it. Hopefully it is the same but I don't know since the Headlight housing is different.
Maybe Dixit or Ice will know since they did the 2K2 HID swap on their cars.
TIA
Jeff
TIA
Jeff
rear corner rewire
TIA
Jeff
TIA
Jeff
TIA
Jeff
TIA
Jeff
Jefferdy1, what you mean about the rewire on the 02? You mean the foglight and/or the corner lights rewire? It should be the same. Maybe not the foglight rewire though.
Dixit
Originally posted by BigDogJonx
Well as far as which green wire to tap, you want to tap the one that is going to the SIGNAL. Not the parking/stop lamps.
Dixit
Dixit
still confused
Dixit
Dixit
both green wires go into the same harness and if i remember this right i think they are side by side. someone on here said you tap the black wire for the back.......but anyway, im still confused with the back corner rewire.
Yeap that is where most people seem to fail on the writeup. Definetely need to CUT the ground wire on the sidemarkers and tuck away the cut one and splice it to the tapped wire.
Dixit
Dixit
Re: Re: http://www.geocities.com/amixam69/nissan/siderewire/
That's easyier if you follow the directions properly. I also updated them for people that can't read.
Re: still confused
The Frye
Sep 2, 2021 11:03 AM
boomerbrian
Sep 2, 2015 03:46 PM
