Rear Rotors wont come off
Old Feb 15, 2009 | 06:19 PM
Majestic Ken's Avatar
So we were installing my BBK today. the front is done. the only problem we have is taking off the rear rotors because i have some nice ones to install. they've never been taken off the car since day 1 i think. we tried the mouse milk to taking all kinds of mallets to it and it wouldn't budge. any clue??
Old Feb 15, 2009 | 06:28 PM
irish44j's Avatar
retired moderator
if you're not re-using the old ones, just smack them with a mini-sledge/BFH. A mallet won't do jack. Sure you'll ruin it...but who cares...you're replacing them anyhow and rear OEM rotors are super-cheap...
Old Feb 15, 2009 | 06:31 PM
well actually someone is gonna use them. yea we took a sledge to them also. we even tried to take off the whole assembly
Old Feb 15, 2009 | 06:49 PM
fishforlife2007's Avatar
i know on the front there are threaded holes to back the rotors off of the hub. i forget if there are ones on the back too...you could try checking that out. if that dont work, get some aerocroil, or pb blaster....soak it....wait.....return with bfh.
Old Feb 15, 2009 | 06:51 PM
knight_yyz's Avatar
Toolie
I had the same problem, grab some liquid wrench and spray the backside of the rotor as best you can. Let it sit for a while. OEM's don't have jack screws on the rears, but some aftermarkets did put them on. Don't forget to put antiseize on the new rotors
will try that. if anything i cant get to this task again until next saturday, so i'll just soak up as much info as i can until then
Old Feb 15, 2009 | 06:55 PM
mist max2000's Avatar
reading material from a quick google search
http://www.explorerforum.com/forums/...d.php?t=184553
http://www.thedieselstop.com/forums/...ng-off-196611/
http://www.jeepforum.com/forum/showthread.php?t=537471
most ppl like mallets
Old Feb 15, 2009 | 07:07 PM
oh wow. that 1st link sounds good enough to attempt lol thanks for the info. I'll be ready to attempt some of these things. yea we were so frustrated we just put it off until then. good that i have the fronts on haha thats all that matters for now.
Old Feb 16, 2009 | 12:06 AM
CMax03's Avatar
(PB blaster) Apply the spray into hub area and comeback and force it into the tight areas with some compressed air let it set and smack it around with your BFH. Hurt me, give it to me big daddy, you know that sorta thing.....
Old Feb 16, 2009 | 04:38 AM
nsnrider's Avatar
Old Feb 17, 2009 | 06:38 AM
kvk2003max's Avatar
I had the same problem and even hitting with a Sledge hammer did not work. Loaned a bearing puller from Autozone and that did the trick.
Spray pbblaster / WD40 on the back of the rotors, Tighten the puller considerably and step away. The rotor will come loose in a few mins.
Old Feb 17, 2009 | 08:11 PM
AltiMaxima2000's Avatar
Had same problem when I replaced my rotors last week.
Take a sledge hammer to them, but make sure not to hit anything but the old rotors.
This is the common practice even at dealerships!
Old Feb 17, 2009 | 08:53 PM
wyche89's Avatar
a regular hammer always worked for me.. smack the hell out of it, and you should see rust falling out with each hit.. DONT hit the braking surface of the rotor.. hit in-between when lug nut studs where the rim touches the rotor
matts95max
Apr 23, 2025 10:44 AM
BkGreen97
Apr 2, 2016 05:47 AM
beerman1378
Sep 8, 2015 02:19 PM
crazyespn
Sep 3, 2015 01:30 PM
A32goldylocks
Sep 2, 2015 06:39 AM
