Utec
Old Jul 1, 2009 | 12:30 PM
  #41
pmohr's Avatar
No more Maximas...
Also, why is your TPS reading 74% at rest?
And why would you take pictures of a computer, to load them into a computer to post them here? Learn the power of the 'print screen' button.
Old Jul 1, 2009 | 12:51 PM
  #42
RacerX1320's Avatar
If its not even turning over its a wiring issue man, re check the wiring once it turns you can go from there and in pin point what the car needs to fully turn over.
* Language barrier over the net for the loss.
Old Jul 1, 2009 | 12:53 PM
  #43
pmohr's Avatar
No more Maximas...
Turning over is generally interpreted as starting, not cranking.
90% of the time I see it as this meaning, but every so often someone calls cranking 'turning over'.
Indeed, incorrect terminology just makes things so much harder for everyone.
Old Jul 1, 2009 | 01:11 PM
  #44
N16_VQ_SWAP's Avatar
I check tomorrow the spark, fuel and injectors WITH UTEC
w/o Utec runs the engine!
Yes... why is my TPS so high?
I have connect:
all 6 injectors
all 6 coils
TPS1
MAF
Intake temp
CKPOS
KS
Power
Ground
more not!
Its all Utec settings OK??
But my CKPOS is damage.
How can i change the TPS reading?
Is that the problem?
PLease help me
Old Jul 1, 2009 | 01:29 PM
  #45
pmohr's Avatar
No more Maximas...
I have connect:
all 6 injectors
all 6 coils
TPS1
MAF
Intake temp
CKPOS
KS
Power
Ground
more not!
PLease help me
You probably connected to the wrong TPS wire. There are two, they have opposite readings. What wire color did you tap into for the TPS?
If your CKPS is damaged, why don't you replace it? It will cause a very hard start, and depending on what you've done to your wiring, very well might not start at all.
Which wires did you intercept, which did you tap?
Old Jul 1, 2009 | 02:09 PM
  #46
SurraTT's Avatar
HR Swap Pioneer
you NEED
TPS 1
TPS 2
APP1
APP2
if the utec is NOT getting these it will read 74% , like when the utec is given power out of the car, for updating or map editing etc...
Old Jul 1, 2009 | 02:17 PM
  #47
pmohr's Avatar
No more Maximas...
Originally Posted by SurraTT
you NEED
TPS 1
TPS 2
APP1
APP2
Interesting.
Old Jul 1, 2009 | 02:27 PM
  #48
you NEED
TPS 1
TPS 2
APP1
APP2
Are you sure?
All tell me only TPS1....
Is that my Problem why the engine dont start?
now TPS1 white wiring (pin 50 at the 350Z ECM
TPS2 is blue and not connected
Supra TT which other wiring must connected
TPS1 + TPS2
APP1 + APP2
more??
thanks!
Old Jul 2, 2009 | 01:30 PM
  #49
so, i have installed TPS2 and APP1+2 and now is my TPS reading 0% and not 74% :-)
But the engine dont start! My injector dont work!
Its all correct connected, i have check it.
It is a wrong setup setting?
My coils work, i have spray break cleaner into the manifold ;-)
Fuel pump work!
Old Jul 2, 2009 | 01:32 PM
  #50
pmohr's Avatar
No more Maximas...
Fuel pump work!
One quick and easy check for the injectors is check the security light, it shouldn't be on when cranking or with the key on.
Does the tach show anything while cranking?
Old Jul 2, 2009 | 03:05 PM
  #51
hello
do you mean the MIL into the cluster? My tach dont go! I have a sentra tach ( 4cylinder) and the max tach have a other impuls.....
I dont understand what do you mean.
Sorry my englisch is not so good.
I think its a wrong setting???
SurraTT have you a pic from your Utec Dashboard?
Is my MAF Voltage to low (1,07V ) ?
Old Jul 2, 2009 | 03:23 PM
  #52
pmohr's Avatar
No more Maximas...
hello
SupraTT have you a pic from your Utec Dashboard?
No, not the CEL, the security light.
Why are you using a Sentra tach? That doesn't even make sense.
Nevermind, I see you swapped into a Sentra. Actually mentioning that in the first post, rather than a small 'by the way' would be helpful. You know, minor details.
So it runs without the UTEC? Has it ran since the last time you disconnected the battery?
Old Jul 2, 2009 | 03:37 PM
  #53
where is the light?
Yes i have a Nissan Almera N16 ( its the same as the Sentra B15 )
And i swap a VQ35DE into my Car. The engine run w/o Utec. I drive with it last week.
which details you are need?
Yes the battery was disconnected but not at the start. i have programm the TB but with UTEC it dont start.
Is all oem settings from utec OK for a start?
i dont change settings!!!its all from the turboxs Homepage.
must i connect the start wiring from the ignition key / max ecm?
Old Jul 3, 2009 | 01:37 AM
  #54
where is the mistake???
must i change any settings?
can anyone check my settings at my pics?
Old Jul 3, 2009 | 02:02 PM
  #55
Must i connect the HO2 sensors?
From the ESM:
On Board Diagnosis Logic
NFEC0912
With the Air/Fuel Mixture Ratio Self-Learning Control, the actual
mixture ratio can be brought closely to the theoretical mixture ratio
based on the mixture ratio feedback signal from the heated oxygen
sensors 1. The ECM calculates the necessary compensation to
correct the offset between the actual and the theoretical ratios.
In case the amount of the compensation value is extremely large
(The actual mixture ratio is too lean.), the ECM judges the condition
as the fuel injection system malfunction and light up the MIL
(2 trip detection logic).
PLEASE can anyone tell me which all terminals i need!?!? PLEASE....
And what is with the START SIGNAL ???
Old Jul 4, 2009 | 09:08 AM
  #56
PLEASE PLEASE PLEASE HELP ME
Old Jul 5, 2009 | 03:06 PM
  #57
why don't answered anyone of my question?
Cotozic
Jun 28, 2017 08:01 PM
MaxInfamy
Forced Induction
Aug 24, 2015 12:01 PM
SurraTT
277
May 24, 2013 06:30 AM
Gemner
43
Feb 5, 2011 12:26 PM
sparks03max
Mar 20, 2009 12:04 PM
