Brake Pedal Pressure Issue
Old Feb 23, 2009 | 06:55 AM
Max_Man116's Avatar
this passed weekend i did my rear brakes, which is nothing new to me ive done pads millions of times but this time it was different. they came off perfect and went on perfect but the fluid reads MAX now and doesnt feel like alot of pressure in the pedal. i can still stop but now how it should or i want it to .. how do i get fix this problem
Old Feb 23, 2009 | 08:03 AM
Lontar1's Avatar
Puerto Rico-Maxima Lover
try bleeding them and see if that helps....
Old Feb 23, 2009 | 08:18 AM
Max_Man116's Avatar
iight ill try it ....it happened when i did the rear brakes so should i stated with the back first ?
Old Feb 24, 2009 | 08:50 AM
NisTech's Avatar
did u open up the lines?
i have seen those calipers seize up and if pedal is being applied it won't hold the wheel turning by hand
Old Feb 24, 2009 | 06:06 PM
SilverGLE's Avatar
I'm watching you, boy...
From the FSM: RR, FL, RL, FR...
Old Feb 24, 2009 | 06:54 PM
horsepants's Avatar
My 96 has the front passenger side caliper sticking or sumthing, the back pad is constantly scrubing (new brakes) and the front pad hasn't even made contact with the rotor. I switched the caliper, but same problem. someone said that the master cylinder may only be sending fluid but not allowing it to release somehow. and ive put brakes on the car myself twice before with no problems at all. any advice would be appreciated. thanks
-pants
Old Feb 24, 2009 | 09:11 PM
rroderiques77's Avatar
Demodded and Forgotten
-pants
If you drive a 5.5 gen, make sure the end of the upper front hardware clip sticks through the wear indicator of the pad.
Old Feb 24, 2009 | 10:08 PM
Drockb418's Avatar
get rid of the balla wheels.................
Old Feb 25, 2009 | 06:19 AM
viperboy's Avatar
Old Feb 25, 2009 | 08:59 AM
Max_Man116's Avatar
Originally Posted by viperboy
Man its Feb and i live in Connecticut if i still had thos rims on they would be Garbage lol ...and besides im goin for a new look this spring nothing like it looks in the pic
Old Feb 25, 2009 | 03:23 PM
SteveB123's Avatar
Hmm. that's sounds like the problem I'm having. When I think of stuck caliper, I think of stuck ON. My drivers rear doesn't seem to even apply, as the rotor is rusty as hell.
Time for new caliper.
Thanks for your insight.
Old Feb 27, 2009 | 06:42 AM
Max_Man116's Avatar
Nah wat he means by stuck is when u go to put the cailper back on it wont push back in
lowpost99
Oct 26, 2025 06:53 PM
mvm062
Nov 30, 2020 09:00 AM
Maxima30
Sep 7, 2015 06:13 PM
MidnightMaxima_22
Sep 6, 2015 01:18 PM
A32goldylocks
Sep 2, 2015 06:39 AM
