squeaky sound on turning need help
Old Feb 23, 2009 | 07:36 PM
hotstartup's Avatar
my car makes a squeaky whinny sound when i am turning, only really happens when i am turning to the right.any clue what could be causing it?
Old Feb 23, 2009 | 08:13 PM
maximase86's Avatar
I love lamp.
First things I would look at is the axles. You could have one that's bad. Also the wheel bearings are the next thing I would look at. Also check out your power steering...make sure the fluid level is okay, make sure the belt is all right.
S
Old Feb 23, 2009 | 08:55 PM
rroderiques77's Avatar
Demodded and Forgotten
Does it make noise only on sharp turns or every one?
Old Feb 24, 2009 | 01:36 AM
hotstartup's Avatar
sometimes it'll make the noise not consistent. sounds like its coming from the steering column. no leaks power steering is good, axles im sure are fine.
Old Feb 24, 2009 | 05:44 AM
kahuna825's Avatar
I would check the wheel bearings, maybe see if you have a tear in the boot. The bearing on that side may be drying out.
Old Feb 24, 2009 | 06:22 AM
maximal01's Avatar
i have the same thing on sharp turns on the left side though, i was planning on a new wheel bearing but is only sharp turns
Old Feb 24, 2009 | 01:49 PM
Teddie18's Avatar
It sounds like the spiral cable or the combination switch is squeaking. The spiral cable contains the cables and springs that extend and retract as you turn the steering wheel. The purpose of this is to maintain electrical contacts with the steering wheel as you rotate it. It maintains all of the electrical connections for the air bag and the horn. The combination switch contains the wiper and light controls and it has a component that rotates in order to turn the turn signal off.
Mine squeaks also. I'm going to find out which one is causing the problem and fix it fairly soon.
Old Feb 25, 2009 | 12:11 AM
hotstartup's Avatar
teddie update this thread when you get it done. the sound doesnt bother me to much as long as it doesnt snap i guess.
DJLAX152
May 4, 2021 11:46 AM
Mar 12, 2020 12:06 AM
pears
Sep 18, 2015 05:25 AM
LtLeary
Sep 14, 2015 12:33 PM
