New Maxima, new problems!
Old Feb 25, 2009 | 09:21 PM
nismo97se's Avatar
Hi guys i used to be a 4th gen owner until my car got crushed by a huge sign that fell during a wind storm..
anyhow today i purchased a 5th gen maxima, was really stoked on getting it. 2000 black on black se, 135k..
anyhow so im in the parking lot and i decide to see it accelerate, i put it into second and floor it out of 2nd.. as i was getting to 6.5k rpms i was running out of parking lot room so i braked dropped it into neutral..
HERES THE PROBLEM: rpms stayed at 6.5k!! revving really high, car is in neutral. i got scared and quickly shut it off. anyone know what that could be, i just bought her and its been a downer to me. thanks!
Old Feb 25, 2009 | 09:40 PM
ActofGod's Avatar
faulty throttle position sensor? Hook that sucker up to a diag, I'm sure it'll show up. Did the pedal get stuck?
Old Feb 25, 2009 | 10:02 PM
maximase86's Avatar
I love lamp.
I assume you're auto correct? Has the car driven normal after that?
Old Feb 25, 2009 | 10:18 PM
nismo97se's Avatar
nope its standard 5spd. driven okay, havent tried to push it again since.. my cel light is on for a secondary o2 sensor so i dont know if anything else has triggered a warning.. il try to get a scanner tool from my buddy asap.
all feedback is greatly appreciated, will look into the tps..
Old Feb 25, 2009 | 10:41 PM
Feldman's Avatar
get your codes checked. my guess is your throttle stuck open either at the pedal or at the throttle itself. how does your pedal feel when you go through the motion? is it nice and smooth? I would personally check for build up at the throttle body end
Old Feb 27, 2009 | 08:27 AM
kahuna825's Avatar
Also check to make sure the cable is not sticking. It could be frayed at some position and will not allow it to retract to home position.
Old Feb 27, 2009 | 08:30 AM
LA02MAX's Avatar
Definitely check the throttle cable and the throttle body. It sounds like something got stuck. have someone push the pedal down (with the car off) while you observe to see if it snags on anything.
Old Feb 27, 2009 | 01:05 PM
6SPD02SE's Avatar
Arent they drive by wire like the 5.5 gen???
Lakersallday24
Nov 7, 2024 07:31 PM
Lakersallday24
Jun 16, 2019 01:35 AM
Samedi
Aug 13, 2015 04:05 PM
Hawkeye61
Aug 12, 2015 06:45 PM
yat70458
Aug 3, 2015 01:16 PM
