ONLY GRINDING INTO 3RD. NEED YOUR OPINION PLEASE!!
Old Mar 3, 2009 | 05:36 PM
rroderiques77's Avatar
Demodded and Forgotten
I wanted to get your opinion on something. I have 02 SE 6-speed and it mostly grinds into third. It won't grind if I slowly shift out of 2nd into 3rd. But during fast shifting it grinds. I was thinking maybe a synchro going out, but wasn't sure. Transaxle has been recently flushed out with Mobil 1 synthetic. Fluid level is to the fill hole. 65K miles. What could it be?
Old Mar 3, 2009 | 05:39 PM
PulsarGTS's Avatar
Its the syncho, unless you are letting the clutch out before shifting to 3rd which I doubt. Its not uncommon with these trannies.
Old Mar 3, 2009 | 08:28 PM
NisTech's Avatar
it's a known issue with these trannies if u search but if u use gl5 fluid it will make it waay worse/develop a problem. make sure you have some gl4 fluid like redline
Old Mar 3, 2009 | 08:55 PM
Yeah, I used Mobil 1 synthetic. It is GL4
Old Mar 4, 2009 | 11:56 AM
Rydicule's Avatar
Don't you know who I am?
Redline MT-90 is your friend.
Srsly.
Old Mar 5, 2009 | 01:05 PM
Derrick2k2SE's Avatar
Very common problem on the 02/03 cars. The syncro is poorly designed. It usually doesn't cause a major problem though. Nissan fixed the problem in the 04 models.
Old Mar 5, 2009 | 01:27 PM
nismology's Avatar
Mobil 1 doesn't make a GL-4 fluid. Drain and refill with something else like Redline or Amsoil.
Old Mar 5, 2009 | 01:35 PM
Ahmad_1290's Avatar
Srsly.
+1
I just switched to it. Tons better
Old Mar 6, 2009 | 02:23 PM
Puppetmaster's Avatar
http://forums.maxima.org/5th-generat...ar-crunch.html
REDinLV
Aug 15, 2024 12:30 AM
Excalibur23
Oct 13, 2015 04:33 PM
carlosvq30
Sep 26, 2015 09:44 AM
dvcamp
Sep 18, 2015 10:17 AM
