Car wants to stall when starting.
Old Mar 9, 2009 | 02:06 PM
MyownNismo's Avatar
Future Camaro SS owner
My car wants to stall once I start it up not all the time. If the car has sat for a while like for a day it starts fine. but if I go somewhere after I have been driving it will sputter then runs fine after getting started. sometimes it doesn't want to start on first try. I had the problem before and had replace a fuel line due to a damper going out. I changed that last year. Now problem the problem is back. I have 155,000+ miles on it. I got no SES light. I can hear my fuel pump kick on before I start the car and hear it when running. any info can help before taking to dealer.
Old Mar 9, 2009 | 02:37 PM
maximadudeIIs's Avatar
Fuel injectors maybe? My neighbor's Nissan Quest did this occasionally and replacing the injectors solved the problem.
Old Mar 9, 2009 | 04:10 PM
Scottwax's Avatar
That's Mr. Detail to you
Hot restart? Look at the IACV.
Old Mar 9, 2009 | 06:23 PM
nsnrider's Avatar
what temperature outside? Maybe just experiencing cold days hard starts?
When was the last time you replaced your spark plugs?
Old Mar 9, 2009 | 06:48 PM
MyownNismo's Avatar
around 36 degrees. It did this before in the summer time too. spark plugs are good.
Old Mar 9, 2009 | 07:08 PM
Tukata's Avatar
When you say Spark plugs are good...
Do they just look good or are you getting an equal quality spark? Did you just do plugs or what else have you serviced on the spark side of this?
Old Mar 16, 2009 | 05:15 PM
MyownNismo's Avatar
I know what it is. It's the fuel damper off the fuel rail. I had replaced it before when having same problems. If you smell gas under your hood that's what it is. I replaced it once before and now it's done it again. Now I want to look for aftermarket parts to redo the lines.
Old Mar 16, 2009 | 07:24 PM
03blackSE's Avatar
How did you go about diagnosing this? I have the same problem; occasionally on hot restarts my could would start up fine, then the rpms would drop like its going to stall out and then come back alive. Very rarely (twice in the 1.5 years I've owned it) has it actually stalled.
Do you always smell gas under your hood, or only when you run the car and go to start it again?
Old Mar 16, 2009 | 08:01 PM
MyownNismo's Avatar
I have change the line before back in August back when I had the problem. Now I am looking at making my own line with FPR. Just figuring out what I need.
MikesChevelle
Nov 23, 2024 11:17 AM
Lakersallday24
Jun 16, 2019 01:35 AM
kjlouis
Nov 24, 2018 06:09 AM
Balkins
Aug 12, 2015 06:39 AM
Tanvirkamal
Aug 5, 2015 01:32 AM
