LED's from V-LEDS....
Old Mar 11, 2009 | 04:38 PM
6SPD02SE's Avatar
I ordered LEDs for my interior from V-LEDS. I installed them today and when i plugged in the LED board for the dome light the LEDs have a slight glow when the switch is on the "door" setting. They turn completely off when i turn the switch to off. Does anyone else have this issue or is there something wrong with mine?
Old Mar 11, 2009 | 04:40 PM
03VQMAX's Avatar
Happens to mine, really doesn't bother me. I guess its normal
Old Mar 11, 2009 | 04:55 PM
6SPD02SE's Avatar
im just worried that it will drain the battery or set the alarm off from the current draw...
Old Mar 11, 2009 | 04:59 PM
03VQMAX's Avatar
No it wont, only stays dim when the engine is on. Ive never loss power nor had my alarm go off.
Old Mar 11, 2009 | 05:58 PM
johnnyd2k2's Avatar
no issues here either and like he said once the engine is off the light goes completly out. I have the same issue with my door leds 5smt 194 bulbs they're dim when I shut the car off but once I lock the doors they go completly out, I believe both issues are due to lack of built in resistors.
Old Mar 11, 2009 | 06:02 PM
fflint_18's Avatar
My dome does the same thing. Only when running. Freaked me out for a couple weeks and no issues so I went with it.
6SPD02SE's Avatar
Mine stays dim even when the engine is off and the doors are locked. The only time they are completely out is when i turn the switch to off.
Old Mar 11, 2009 | 06:13 PM
sascuderi's Avatar
Mine goes off normally. No glow.
Old Apr 4, 2009 | 10:12 AM
DrOmed's Avatar
My dome light stayed on too just slightly. By the next morning my battery was dead! Anyone have a fix to this annoying glow? Otherwise I/m just going to return them. Bought some from a guy on ebay too and they too have the glow, so it isn't just a vled problem. Anyone have a fix for it?
Thanks.
Old Apr 4, 2009 | 10:15 AM
maxfever1987's Avatar
maybe adding a resistor to it can help
Old Apr 4, 2009 | 02:23 PM
DrOmed's Avatar
How do you add a resistor, what kind of resistor, where do you get the resistor etc etc.
Thanks.
Dr.Omed.
Old Apr 4, 2009 | 06:47 PM
Majestic Ken's Avatar
i'm on v-leds also. so which ones did you get? and was it plug and play? pics?
Old Apr 4, 2009 | 07:50 PM
anomaly117's Avatar
just get the led dome kit from www.paradox-systems.com i got mine there works like a charm. its cheap too like $12
Old Apr 5, 2009 | 06:15 AM
Metal Maxima's Avatar
SHIFT_om nom nom nom
Originally Posted by maxfever1987
Explain what adding a resistor would do.
doctorpullit
Oct 28, 2019 10:58 PM
trsandrew
Apr 8, 2016 06:45 PM
mpbclutch33
Dec 26, 2015 11:11 AM
trsandrew
Oct 25, 2015 02:47 PM
