Replacing radiator, what do you use to plug the transmission cooler lines?
Old Mar 11, 2009 | 07:35 PM
00gxe5sp's Avatar
I bought a radiator on the web and waiting for it to come in. The good news is since I have a few days to wait I can take my time and do the replacement "right". Quick question for those with experience - what do you use to plug the transmission cooler lines (when you disconnect them from the radiator) to keep from losing all of your transmission fluid?
Thanks!
Old Mar 12, 2009 | 06:27 AM
oldngivout's Avatar
Willing to learn
If you don't have a rubber cap of some sorts, you could use a couple of 2" pieces of hose the same size as on the car. Then just stick a bolt in each end to plug them up.
Old Mar 12, 2009 | 07:57 AM
CMax03's Avatar
Or some golf tees!
Old Mar 12, 2009 | 08:06 AM
pmohr's Avatar
No more Maximas...
Either find anything of appropriate size (bolt, golf tee as has been said, etc), or just zip tie them facing upwards as high up as you can get them.
Old Mar 12, 2009 | 09:07 AM
Playa_FL's Avatar
Even if you dont plug the hole, you will still loose a very minimal amount of fluid, but b/c the engine isn't running, fluid wont flow. It has to be pumped through the radiator.
Old Mar 12, 2009 | 10:54 AM
max2001's Avatar
OLD SPARK PLUGS !!
Old Mar 12, 2009 | 01:01 PM
808MAX-SPEC's Avatar
Originally Posted by CMax03
Or some golf tees!
This was a good idea. The golf tee is works but you have to tape it to keep it plug. One less thing to worry about now. All I have to do is order a new radiator cap, hoses and thermostat w/ gasket. [shrugh]
Old Mar 14, 2009 | 07:18 PM
00gxe5sp's Avatar
You guys are awesome. The golf tee worked great. Of course I got to the other line and the tee slipped out (yeah, I used tape) and was followed by only a few remaining drips of trans fluid. So everyone here was right.
Thanks a ton!
Old Mar 14, 2009 | 08:16 PM
twiggy144's Avatar
Dont block the flow of the ATF!!!! recipe for posible transmission damage. Use a piece of hose and a couple clamps to close the loop of the flow between the existing cooling lines .
Old Mar 14, 2009 | 09:39 PM
Ahmad_1290's Avatar
I changed the radiator on my 97 Maxima. It was a 5spd. And i didn't need to plug the lines. I don't know if the year 2000 is different though.
Old Mar 15, 2009 | 04:39 AM
fflint_18's Avatar
Seriously you should be careful with golf tees. I know it will definitely work, but that wood is pretty soft and if you break one off in there you'll have a heck of a time getting it out.
I usually just tie them upward and have a piece of carboard underneath for any minimal amount that leaks.
But the hose idea with bolts is a good idea also.
Old Mar 15, 2009 | 06:46 AM
pmohr's Avatar
No more Maximas...
There is no fluid flow while the engine is off. Did you read the original post? It's not like he's going to be driving around without a radiator...
The 5MT doesn't have trans cooler lines, only the auto.
Old Mar 16, 2009 | 04:35 PM
00gxe5sp's Avatar
Well 120 mile round trip today and no leaks, no smells, no problems. Thanks for your assistance guys.
I have been thinking about selling the "I" to get another 5 speed, but the funny thing is....after getting so "intimate" with this one....now we have a connection. I think she would get her feelings hurt if I posted her for sale? Anyone ever experience this ridiculous feeling before?
Old Aug 25, 2015 | 07:41 AM
famouspork's Avatar
yes Ive dealt with that feeling
I have a 6mt 03 max and I love it. Even drove from Montreal to NYC and drove it though Manhattan, which was a dream come true for me. But the weirdest case was with an 01 durango i bought in dexember last year. Drove that old badass **** all winter on a locked diff and no front driveshaft, I loved the sound of it, the oversized tires and rugged body. But I found an 02 with an absolutely clean body, clean engine, and when I sold the older one I felt bad for abandonning it hahaha! But the guy who bought it really loved it, even with its little rust spots and mechanical woes and fixed it, so i felt better after that LOL
Old Feb 1, 2016 | 12:44 AM
link375's Avatar
I just replaced my radiator and didn't have to plug the lines on my 2002 maxima.
Old Feb 2, 2016 | 10:30 AM
Child_uv_KoRn's Avatar
Bad *** Newb
Plug lines with no pressure? Clamp some vice grips on loosely or just stuff them ends up, so nothing drips out.
MAXSE5SPD
Aug 23, 2015 12:06 PM
Maxboy23
Aug 21, 2015 11:02 AM
Balkins
Aug 12, 2015 06:39 AM
kirkhilles
Aug 8, 2015 10:53 AM
Tanvirkamal
Aug 5, 2015 01:32 AM
