2K1 Lifter noise??
Old Nov 18, 2001 | 07:17 PM
BuddyWh
2K1 Lifter noise??
This has happened to my 2k1 twice now... when I start it after sitting for a couple days, there will be a very brief soft clatter. Sounds like cold-start lifter clatter that was common in older American V6's and V8's when the oil would drain down to the pan, starving the lifters for oil until it was pumped back up. Only in my Max it is much softer sounding and much shorter in duration.
It was considered fairly normal in those old beasts, and a good reminder to let the motor idle a little before driving away. Is this normal for Maxima motors? Like I said, this has happened only twice yet I frequently let the car sit in the garage for two-three day intervals.I have 29,000 miles on it and run 10w-30 oil.
BuddyWh
Old Nov 18, 2001 | 07:20 PM
BigDogJonx's Avatar
Re: 2K1 Lifter noise??
BuddyWh
Well it can happen, since the 10W oil is kinda thicker than 5W and when it sits there, there aint much oil up in the lifters.
Old Nov 18, 2001 | 07:54 PM
TimW's Avatar
The silent but deadly Moderator
remember...
you have a metal timing chain. it may sound like lifters. then again, lifters can do this, but it may be as simple as a noisy cold chain.
Old Nov 18, 2001 | 10:21 PM
Mike S.'s Avatar
not an issue at all. I just heard a near new MB E320 do it tonight...light clatter for a couple secs till the oil moves.
Old Nov 19, 2001 | 03:35 AM
UMD_MaxSE's Avatar
Got Bent?
mine does it also for a few seconds after a cold start.... the chain causing the slight noise does make sense
Old Nov 19, 2001 | 06:43 AM
mike-777's Avatar
With dual overhead cams and all the valve train hardware, these engines will be a little rough sounding upon start up.
This is why I use Mobil 1.
I used to have a 1970 Ferrari 365 GT 2+2 and after sitting for a few days the noise on start up was really gut wrentching. 12 dry cyclinders and valves made quiet a racket. This really bothered me.
My old 89 SE Max with single cams made virtually no noise on start up.
TallTom
57
Oct 14, 2025 05:16 PM
user 11122324
42
Jul 18, 2022 03:35 PM
Miket2006
Mar 1, 2021 03:55 AM
D Mason
Jun 21, 2016 04:43 AM
uttadms31
Sep 30, 2015 05:24 AM
