REPLACED BRAKE PADS!!! HELP!!!!
Old Mar 20, 2009 | 11:47 AM
Nevermore's Avatar
well I replaced the front brake pads on my 02 maxima. and bled the lines as well. but when I have the car off it has pressure in the lines but when the car is on it loses pressure and the pedal goes to the floor with ease.
we didnt take anything off, except the calipers to get the brake pads off.
any solution?
also we test drove it around the block and the wheel area got really hot and noticed the calipers were not releasing any ideas?
Old Mar 21, 2009 | 01:06 AM
SilverGLE's Avatar
I'm watching you, boy...
Air in the brake lines; re bleed.
Old Mar 21, 2009 | 04:40 PM
Nevermore's Avatar
well we bled the lines and got all the air out...but when we replaced the pads they were too frickin big and wouldn't even let the wheel spin freely so I just put the old ones back on that still have alittle more meat left on them. and my braking is back to normal. except when I brake hard at 80 it has a jerking feeling...maybe something wrong with the rotors?
Old Mar 21, 2009 | 05:11 PM
DoubleOmax's Avatar
did u compress the piston in the caliper?
Old Mar 21, 2009 | 09:39 PM
rroderiques77's Avatar
Demodded and Forgotten
The rotors are warped for sure. The new pads may have been defective or improperly installed. Exchange them for a new set and try again. If problem persists, replace the front calipers as you may have one hanging up.
Old Mar 21, 2009 | 10:12 PM
Progress's Avatar
It's business time.
Why would you replace the pads without turning the rotors?
Old Mar 22, 2009 | 04:14 AM
vastmax's Avatar
or better yet, remove the brake lines just to replace the pads...
Old Mar 22, 2009 | 07:04 AM
ZIPPIN's Avatar
Mauja He Mauja
+1. And you dont want to use new rotors with old pads...
Old Mar 23, 2009 | 05:06 AM
SilverGLE's Avatar
You mean the OP has uneven pad material that's been transferred to the rotor... Turn the rotors with new pads and you should be good to go (unless you do a lot of spirited driving, like autocross).
Except in the case of vibration, it's not necessary.
Maybe he wanted to improve pedal feel...? Or replace the fluid?
Why? No harm, unless there's a vibration. I'm reusing my Hawk HPS with RTP blanks. The HPS have about half the tread left on them.
Old Mar 23, 2009 | 03:51 PM
kdarcangelis870's Avatar
any solution?
Make sure you didn't accidentally break a hose and bleed and rebleed until the pedal feels firm again.
Old Apr 22, 2009 | 02:48 PM
Brucey's Avatar
Bleed em
Hey bud, sounds like u didn't bleed the lines properly try again, and make sure the brake pads have thr exact fitment for your ride!
Old Apr 23, 2009 | 11:12 PM
00MAXI's Avatar
Who needs brakes? Just run the car into the tree like those tweakers in Arkansaw who were trying to defraud the insurance company.
The only problem was the insurance company got ahold of billybob's camcorder that had the video of them repeatedly ramming the car into the tree.
One of the tweakers ratted him out for some fresh green glass yummmm.
Anyway just kidding I think you should bleed the brakes again or even tow that sucka to a brake shop.
Matt93SE
May 24, 2019 02:58 PM
rbuswell
Nov 17, 2016 04:54 AM
homeyclaus
Sep 3, 2015 06:15 PM
Cant_Get_Ryte
Aug 28, 2015 06:41 AM
RealityCheck
Aug 5, 2015 06:18 AM
