Replacing Lower Oil Pan on 5.5 gen.....Anyone?
Old Mar 23, 2009 | 09:14 AM
Zack342's Avatar
Just wondering how many folks here have had to replace the lower oil plan on their 5.5 gen? On my car it is really rusted althought not leaking or anything. So I wanted to replace it, wasn't sure if anyone in here had done so and if they did if the could provide some tips?
Anyone have the Nissan Part # for the oil pan and bolts?
Old Mar 23, 2009 | 10:53 AM
MintVQ35's Avatar
I have a new lower pan sitting in the closet waiting to be installed on my 02, mine is very rusty also. I know I got mine for a lot cheaper than the $90-100 I am seeing online but I can't seem to find where I ordered mine from, the OES part # is W0133-1722972. My brother replaced the lower on his 02 Altima 3.5, said it wasn't too bad just gotta remember that you need to "make" the gasket for it using silicone, think he said he used Permatex Ultra Grey RTV Silicone and no issues since.
Old Mar 23, 2009 | 06:16 PM
diverdown3's Avatar
You might want to have brake cleaner handy to clean the mating surfaces of oil prior to reassembly. I spayed it into a clean rag and used it to wipe the surfaces.
Old Mar 23, 2009 | 07:29 PM
Zack342's Avatar
Anyone have the part #? The one listed above is wrong
Old Mar 23, 2009 | 10:34 PM
navigator82's Avatar
i just change mine 2 months ago, i buy the pan for infinityparts.com for 87 bucks, use permatex silicone grey high temperature (autozone 10 bucks) and take me lime 20 mins to install and 24 hrs to fillit with oil, no problems since, just make sure to scrap all the old gasket and cleaned with tinner works for me if you have any problem letme know good luck
Old Mar 24, 2009 | 05:07 AM
Zack342's Avatar
Do you have the part # of the oil pan?
Old Mar 24, 2009 | 07:06 AM
diverdown3's Avatar
- Oil pan
(11110+A)
11110-A33B003
- Oil pan bolts
(11110F)
11035-A33B001
Old Mar 24, 2009 | 07:12 AM
oldngivout's Avatar
Willing to learn
Just so you know, those part numbers are specific to Courtesy Nissan only.
Your local dealer, or any other for that matter, won't be able to use them.
Call the parts dept. - they will be able to help.
Old Mar 24, 2009 | 07:29 AM
diverdown3's Avatar
I have the FSM and apparently it has no part numbers. Is there an online source you know of?
Old Mar 24, 2009 | 07:31 AM
importcf's Avatar
the dealer is doing it on my "new to me" 03 SE 6spd 48k miles for free
Old Mar 24, 2009 | 07:55 AM
vball_max's Avatar
For parts, call or pm DaveB (the parts guy). He will help you out and give you a decent price.
Old Mar 24, 2009 | 09:05 AM
CMax03's Avatar
Hey will that lower oil pan exchange between the 4th gen and the 5th gens, the drain is in a different location? That would help me since I have Cattman headers!
Old Mar 24, 2009 | 09:45 AM
diverdown3's Avatar
Now that is a great question. In for the answer.
Old Mar 24, 2009 | 10:00 PM
oldngivout's Avatar
Willing to learn
I have an 04 pan on a 98 car. Drain plug is in a different place, but it still fits & works just fine.
Old Mar 24, 2009 | 11:45 PM
CMax03's Avatar
talk to Dave B today He stated that 4th gen Vq's and 5th gen Vq's all have the same upper oil pan assy which would mean all the lower pans are interchangeable between the 3 engines
Old Mar 25, 2009 | 09:30 AM
Zack342's Avatar
Did you by chance get the part #'s ?if you did could you post them for the group
Old Mar 25, 2009 | 12:39 PM
SpooledVQ35's Avatar
Yes just get the lower oil pan from a 6th gen maxima and it will have the drain in a different location
Old Mar 25, 2009 | 07:14 PM
CMax03's Avatar
What location is that? My VQ35's drain plug is on the aft (rear) side of the pan , more thank likely the same location as yours, so thanks not gonna help!
Old Mar 7, 2012 | 06:03 PM
trackrunner1388's Avatar
[/quote]
go to this websites to get car parts..www.rockauto.com, i got my oil pan and gasket for 57.00 bucks, everything is cheaper than autozone and other stores
Old Mar 7, 2012 | 06:21 PM
JandSauto's Avatar
I have swapped from 02 to 06 man and auto oil pans. 02/03 uppers are the same for auto and man trans. 04 to 06 Auto pan will take the 02/03 upper and lower pans.
By the way the Auto pan bolts (upper not lower) do not all work as they are different length's ( i think 3 of them). I'm almost 100% sure from 02-06 the lower pans are all the same.
You will need (to replace it)
1) Ratchet (3/8's)
2) At least a 6 inch extension (3/8 lol)
3) 10mm (3/8)
4) Razor blade (cleaning old goop off)
5) REAL brake clean to clean new goop surface.
6) Flat head screw driver and a small hammer to pry off old oil pan (lower lol)
7) Once oil pan is off go get a sandwich and a beer. Sit for 30 min and let it drip into oil bucket (messy).
Don't forget to DRAIN OIL!! Best time to do it is when it needs an oil change! 14mm head , Best to use a lift or ramps. IF U USE A JACK PLEASE PUT JACK STANDS IN SOLID SPOTS EVEN IF JACK STAND IS STILL HOLDING IT UP!!! Also put e-brake on to make sure car stays where you park it (on solid flat ground). If I missed anything sorry!
James
You may want to get new bolts!!
Old Mar 9, 2012 | 06:59 PM
cainecabe's Avatar
just did this actually...
i jut replaced my lower oil pan as well (03 SE) due to bad rust on it. I also had to change the lower part of the oil cooler pipe as it was badly rusted too. So, you may want to confirm that it too doesn't need changing.
The swap was a piece of cake for the oil pan though... drain oil, drop pan, wait a while, razor blade the old goop off, and then wipe off any excess junk.
I got my oil pan from AdvanceAuto for $70 i think, plus a gasket. I also used RTV Blck when putting things back together.
Worked like a champ.
Good luck.
Old Mar 9, 2012 | 07:09 PM
gatsugansu's Avatar
Good luck.
May I ask where you bought the oil cooler line? Mine is so rusted, looks scary.
Old Mar 10, 2012 | 05:02 AM
cainecabe's Avatar
i bought that at the dealer... booooo. ineeded it tht day and was therefore my only option. charged me $35 instead of Courtesy Nssan's $25.
tht too was an easy swap. Except that more coolant fluid comes out than one may expect f not ready for it. Be sure to dd the coolant flud back, or use this as an opportunity to flush and refill the coolant.
tcb_02_max
Sep 11, 2015 12:23 PM
homeyclaus
Sep 3, 2015 06:15 PM
maxinout93
Aug 20, 2015 02:17 AM
classymax420
Aug 6, 2015 06:35 PM
maxima297
Aug 3, 2015 12:50 PM
