HELP - failed emissions
Old Mar 26, 2009 | 06:13 PM
maxdriver10's Avatar
Okay so the other day i failed my emissions testing (live in CT) because i ran a PO420 code...i need to replace the cat and was looking for an aftermarket one. I am thinking this warpspeed one w/y pipe http://cgi.ebay.com/ebaymotors/WARPS...mZ300296591671 but need to make sure it will still pass emissions....anyone have any experience with it? they claim you will still pass since the y pipe doesnt remove any precats but i am just checking
Old Mar 26, 2009 | 09:28 PM
CMax03's Avatar
I ran a Cattman Ypipe, Wsp MS cat, Cattman catback, and passed for 4 yrs straight. So just fix your problem with some performance bolt-ons and clear the codes. During the emission test they're basically just looking for stored codes, leaking fuel caps, and the obvious safety violations such as bald tires, missing lug nuts, non-working lights, etc....
Old Mar 27, 2009 | 08:19 AM
pmohr's Avatar
No more Maximas...
An emissions test has nothing to do with safety equipment.
OP: If you're just looking to pass emissions, you could always use an O2 sim to get rid of the code. That's all the emissions station is going to do, check OBD-II readiness monitors and DTCs.
Originally Posted by http://ctemissions.com/expect-newer.html
The OBD test is quick and easy. The inspector connects your on-board computer, which continuously monitors the engine and emissions controls, to the inspection computer and downloads the data. The results are printed on the Vehicle Inspection Report (VIR) that you receive at the end of the test.
If you pass the OBD test, you pass the emissions test.
Old Mar 27, 2009 | 06:45 PM
how do I clear the codes
Old Mar 27, 2009 | 09:38 PM
nsnrider's Avatar
Get the ECU reprogrammed. When I had a p0430 code on a 2000 maxima, dealer told me that I needed a new pre-cat and if it was a p0420 then a lot of times you can get away with resetting a few parameters when having the computer reprogrammed.
I vote on getting the O2 simulators.
Old Mar 28, 2009 | 04:55 AM
And I can pick up o2 sims at autozone/advanced auto and they're easy to install?
Old Mar 28, 2009 | 05:02 AM
Max_Man116's Avatar
i have put one i yet but ive got a p0430 so i will be doin it soon but heres a good write up on how to install it
http://forums.maxima.org/5th-generat...tallation.html
Old Mar 28, 2009 | 11:16 AM
Thanks for the info
Old Mar 28, 2009 | 12:13 PM
jjdamien's Avatar
I'm selling that exact cat converter you were looking at on ebay. I purchased it with the 2000 FED spec y pipe.
Heres the link with pics.
http://forums.maxima.org/5th-generat...-flow-cat.html
gustavison
Oct 4, 2015 06:50 PM
JoshG
51
Sep 21, 2015 10:41 PM
DayHeyZeus
Sep 11, 2015 03:17 PM
carid
Sep 9, 2015 05:06 AM
