Whining noise after cleaning the throttle body...clueless.. help please..
Old Apr 6, 2009 | 05:42 AM
vvtli78k's Avatar
hi guys... 1st the battery dies .. it was an original.. by the way this on a 02 Auto ...changed the battery.. then the dile would not hold.. would start it up and it would die. Pulled a p0506 code... i took apart the air intake system and cleaned the throttle body according to a procedure posted here on the forums. so now that problem is fixed, the check engine light is gone but there is a whining noise and it gets louder with more throttle... car drives ok. and i checked for leaks 3 times from all the hoses and clamps i put back related with the air intake system...
any clues?
Old Apr 6, 2009 | 11:49 AM
jasonmax's Avatar
any clues?
vacume leak?
Old Apr 7, 2009 | 08:02 AM
vvtli78k's Avatar
That is what I thought.. but i checked and re-tightened every screw/bolt I opened...
Old Apr 7, 2009 | 08:32 AM
Professor's Avatar
spray with starter fluid while its running, if a leak is found, it should change the sound of the engine idle
Old Apr 7, 2009 | 10:02 AM
jasonmax's Avatar
my car has a high pitch whining when running, it's not from the intake, more like from the manifold area where it goes into the engine.
JoshG
51
Sep 21, 2015 10:41 PM
bumpypickle
Sep 20, 2015 08:22 AM
Bonka
Sep 14, 2015 11:18 PM
Maxxx10
Sep 13, 2015 03:16 PM
thenewguyy
Sep 12, 2015 11:12 AM
