Help with Umnitza HID fog install
Old Apr 14, 2009 | 11:55 AM
Weeble1's Avatar
The Whistle go WOOOOO
Anybody know a good way to seal the rear of the fog housing after installing the umnitza HID fogs? I am lost on this one and can't find a thing when I search. Any help would be great. Thanks guys
Josh
Old May 14, 2009 | 07:24 AM
mannetti21's Avatar
ever get this sorted out? Im going to be installing these HIDs on my 01 tomorrow...Im assuming silicone would seal up the drilled hole? Or is the problem that the H3 bulb is too long
Old May 14, 2009 | 07:34 AM
Stormzusmc's Avatar
Bulbs are not too long, and if you need to seal because youre a nub and drilled, then use silicone....done
mine are not from umnitza be you get the idea
Old May 14, 2009 | 07:44 AM
Weeble1's Avatar
My issue was the grommet. You need to cut a circle in the back of the housing. If you cut the right size then there is no need for silicone. The regular bulbs are too long, that's why you should order the H3c bulbs. They are smaller and fit. If you order the regular H3 bulbs then you just bend down the light reflector in the housing. Just stick a screw driver in there and bend it down.
Old May 14, 2009 | 07:50 AM
mannetti21's Avatar
wish I knew to order the H3c's.....and so much for PnP, any way to avoid the drilling?
And what diameter did you use? Umnitza recommended 1" but 7/8 looks like it might be a better fit
Old May 14, 2009 | 07:54 AM
Stormzusmc's Avatar
precisely! i just soldered and heat wrapped the wires instead of all that mumbo jumbo though...
Old May 14, 2009 | 08:13 AM
mannetti21's Avatar
which wires you talking about?
Old May 14, 2009 | 08:14 AM
Stormzusmc's Avatar
are you still trying to make people have a seizure by putting strobes in your break lights? PM me stop posting all over the place about it
Old May 14, 2009 | 08:15 AM
Weeble1's Avatar
There is no way to prevent drilling. Just stick with what they say.
Old May 14, 2009 | 08:16 AM
Stormzusmc's Avatar
um yes there is, mine are clearly installed....with no drilling
Old May 14, 2009 | 08:30 AM
mannetti21's Avatar
wtf?
Old May 14, 2009 | 08:47 AM
Weeble1's Avatar
Explain... how?
Old May 14, 2009 | 08:48 AM
Weeble1's Avatar
wtf?
I was wondering the same thing...
Old May 14, 2009 | 09:05 AM
Stormzusmc's Avatar
wtf?
my bad....was another dude...with a 6th gen....sorry got yalls names confused
Old May 14, 2009 | 09:06 AM
Weeble1's Avatar
Got ya, so how did you now need to drill the back of the housing?
Old May 14, 2009 | 09:10 AM
Stormzusmc's Avatar
Explain... how?
Cut and soldered wires then used heat wrap to seal the wires up
Old May 14, 2009 | 09:23 AM
Weeble1's Avatar
oh I see. You already said that lol. my bad
Old May 14, 2009 | 09:38 AM
mannetti21's Avatar
im still confused, most likely bc i cant remember what the back of the housing looks like
Stormzusmc's Avatar
np, would you like me to show you the wires when i get home?
Old May 14, 2009 | 09:43 AM
mannetti21's Avatar
The Frye
Sep 2, 2021 11:03 AM
MaxLife17
Jun 27, 2019 01:37 PM
Vistance
Sep 17, 2015 05:17 AM
mpbclutch33
Sep 8, 2015 06:21 PM
MaxLife17
Sep 8, 2015 02:36 PM
