Warm start issue
Old Apr 24, 2009 | 04:12 PM
Ridiculous's Avatar
Warm start issue
I have a lot of trouble starting my car when its been running already. Its hard to describe so hopefully this video will help.
http://www.youtube.com/watch?v=gl8VbleeXOE
^Might not be processed yet.
Old Apr 24, 2009 | 05:02 PM
asianstyle's Avatar
mine does this sometimes also too, any ideas anyone.
Old Apr 24, 2009 | 05:18 PM
whitealexander's Avatar
that's strange never encountered it before..
Old Apr 24, 2009 | 09:12 PM
Scottwax's Avatar
That's Mr. Detail to you
You might have a leaking/sticking fuel injector that is slightly flooding the engine when you shut the car off.
Old Apr 24, 2009 | 10:23 PM
asianstyle's Avatar
is there an easy fix for that? doesn't sound like it.
Old Apr 24, 2009 | 11:16 PM
turbizzy's Avatar
Could be a leaking injector or maybe a bad fuel pump. I had an 04 Altima couple days ago that also did this only when it was hot and the car had been running for a while. Fuel pump would intermittently drop pressure when the key was turned off, verified this with a gauge.
Also, even with no check engine light there may be a crank position sensor code stored, have you checked for codes yet?
Old Apr 25, 2009 | 03:55 AM
KRRZ350's Avatar
Clutch, trans, or engine ever been replaced?
Old Apr 26, 2009 | 04:50 PM
Ridiculous's Avatar
Not sure because I am second owner. :/ I deliver pizza and it has yet not to start but I feel like im gonna ruin my engine if I keep doing this.
Old Apr 26, 2009 | 05:33 PM
maximase86's Avatar
I love lamp.
First thought to me is cam or crank position sensor. I would check not only the sensors, but the harnesses. I had a hard start problem as well on my 4th gen S/C'er. The harness for the cam sensor had been damaged before and was fixed. Finally I replaced it and the car started up every time the first time.
S
Old Apr 27, 2009 | 01:43 AM
cmd26's Avatar
S
i brought my car in 04 and my car started doin that same thing last year
Old Apr 27, 2009 | 05:35 AM
Progress's Avatar
It's business time.
Check your plugs, clean your TB and replace your air filter.
Old Apr 27, 2009 | 08:57 AM
turbizzy's Avatar
Well at this point all we can do is wait for the guy to answer. From a Nissan tech's initial diagnosing steps, check for codes, do this before you go replaced chit unless you like spending money.
Old Apr 27, 2009 | 09:40 AM
Ridiculous's Avatar
Yeah I do have a SES light and I'm going to go to autozone soon hopefully tomorrow. But I had the SES before this started happening but I could just have multiple codes now :/
Old Apr 27, 2009 | 03:05 PM
cmd26's Avatar
a maxima owner told me she got her induction n fuel systems cleaned n the problem stopped. also her
car had a recall where replaced some sensors on the engine.
Old Apr 27, 2009 | 05:41 PM
bert's Avatar
That kinda sounds like what mine did, before the starter let go. I would make those noises, basically like the engine would seize while trying to start. and eventually start.
At one point the starter was so weak (after 9 years, 130-140k miles), that one morning if flooded the engine, the ECU went in to freak mode and refused to start. Not only did it cost me a starter, but a towing, oil change and untold frustration that my baby was out of commission.
I don't know if there is any way to test the power / crank power of the starter.
Old Apr 22, 2010 | 02:45 PM
00greymax's Avatar
mines was doing that and as i was pricing a crank sensor it left me sit in the nissan parking lot. they called me today and couldnt find anything wrong with it. mine does it hot warm and sometimes cold. im going to put a starter and fuel pump in mine since the fuel pump sounds kinda grindy at the time that this happens
Old Apr 22, 2010 | 03:32 PM
Child_uv_KoRn's Avatar
Bad *** Newb
Sounds like a GM car lol
MAXSE5SPD
Sep 17, 2022 04:00 AM
mvm062
Nov 30, 2020 09:00 AM
Maxima30
Sep 7, 2015 06:13 PM
trungg86
Sep 4, 2015 04:58 AM
305head
Aug 26, 2015 09:03 PM
