my car is slower with intake!!!!
ever since i installed my intake, my car seems slower!!!i use to b able to hitt 100mph in 3rd now i can only hit 90and below. did i install it wrong??? i have a customized 4th gen weapon r intake (3inch pipe)with cone filter.
Re: my car is slower with intake!!!!
Seems and is slower are 2 different things. I suggest putting the car back to stock and time a 2000-6500rpm 3rd gear pull with a stopwatch. Do this 3 times, then install the intake wait a week and try again.
Originally posted by PhatGuy
An intake can make your car accelerate slower but can't change your speed in any gear! Your gear ratio stays the same! A 5spd redlines about 96mph in 3rd.
I just installed the Stillen Hi Flow on my 02'. It sounds pretty d*&$ good and looks even better. As for performance...it does seem a bit slower of the line. However, I think this car does best when pulling from about 30 or 40 mph anyway. I had an 01', lost to the Houston flood, and it did not pull nearly as hard as my 02'. I have only had the HF on for a day. So I will post in about a week or so with future comments. Enjoy the new sound!
How do you know what to listen for in my case the stillen intake? It makes it's usually light hissing sound etc..
Its been about a week since installing the HF Intake from Stillen on my 02'. I like it a lot. I am considering modifying the factory intake scoop and/or adding additional air supply from below. What is the secondary peice of plastic (looks like a small odd shaped container) attached to the factory scoop/intake about 10" from the very start of the scoop? Is this the "baffle" I read about in the search info. If I can remove it, it will give me room to route an additional 3" tube from below. Yes..I have read some of the archive info. on a search, but missed anything this specific.
http://www.punkdork.net
Originally posted by punkdork
Thats the resonator... check out the OSCAI section of my website.
Originally posted by SprintMax
Intakes increase low end and rob's top end.. to complete this balance you would need to get a Y pipe..
Hmmm I thought for sure it was the other way around? The intakes rob low end and increase high end I always thought? Does it act differently with a stock Y over an aftermarket Y?
Here's my understanding:
A cone intake may not be as effective at low end as a CAI because it is drawing in hotter air from around the engine. Cone intakes have been shown (on this forum) to be somewhat more effective at high speed than CAI on the 4th gens - arguably because of better air flow.
But, either intake is going to be better than stock. Both will increase air to the engine which will in turn increase power. The only reason a cone intake could be less effective than stock is because of heat around the engine.
However, the stock is far more restricted and isn't much better at drawing in cool air. There may be times when the cone intake is worse than stock at low end, but it ain't going to be much/often.
Also, there is no NEED to have a y-pipe for the intake to work. We aren't dealing with forced induction/nitrous. The y will help even absent the intake because it will reduce backpressure. Reduction of back pressure beyond a point WILL decrease low end and improve high end.
Lakersallday24
06-16-2019 01:35 AM
kingw323
20
10-21-2015 08:36 AM
MaximaDrvr
08-19-2015 08:20 PM
Maxboy23
08-11-2015 11:59 AM
