Where is fog light fuse in fuse box?
Old May 2, 2009 | 11:49 AM
n3985's Avatar
大陆弟弟
My HID fogs connected to a relay harness tapped into my factory fog wires stopped working. New relay, new wiring, re-soldered every connection and still nothing. Used a multimeter to test factory wires and getting nothing, all the fuses look good, ideas? I checked and swapped all the "headlight" fuses in the driver's side engine bay fuse box.
Old May 2, 2009 | 01:01 PM
mist max2000's Avatar
dont know if this is what your looking for... but the fuse should be under the hood on the pass side fenderwall near the headlight...search around for the foglight rewire mod and you should find helpful pics.... (assuming its the same as the max..)
Old May 2, 2009 | 01:03 PM
n3985's Avatar
大陆弟弟
Thanks, but I'm pretty sure that's the relay box.
Old May 2, 2009 | 03:38 PM
anomaly117's Avatar
potentially dumb question... check the inline fuses that come with the HID kit?? i had an issue once and forgot all about the inline fuses
Old May 2, 2009 | 03:41 PM
n3985's Avatar
大陆弟弟
Checked those too lol, the relay harness and HID kit are working fine (tested individually), but I'm not getting any power out of the factory wires (to trigger the relay). And I can't figure out which fuses are the fog ones.
Old May 2, 2009 | 04:37 PM
Drockb418's Avatar
there is a fuse for like running lights or something like that ...i dont think there is a fuse for fogs themselves.
Old May 2, 2009 | 04:40 PM
Drockb418's Avatar
OUTLINE
NFEL0164S01
Power is supplied at all times
I to headlamp RH relay terminals 1 and 5
I through 15A fuse (No. 69, located in the fuse and fusible link box), and
I to headlamp battery saver control unit terminal 7
I through 10A fuse [No. 12, located in the fuse block (J/B)], and
I to front fog lamp relay terminal 3
I through 15A fuse (No. 6, located in the fuse and fusible link box).
When ignition switch is in ON or START position, power is supplied
I to headlamp battery saver control unit terminal 1
I through 10A fuse [No. 30, located in the fuse block (J/B)], and
I to headlamp battery saver control unit terminal 10, and
I to smart entrance control unit terminal 33
I through 10A fuse [No. 10, located in the fuse block (J/B)].
Ground is supplied to headlamp battery saver control unit terminals 4 and 11.
When lighting switch is in 2ND position, ground is supplied
I to headlamp RH relay terminal 2 from headlamp battery saver control unit terminal 8.
I through headlamp battery saver control unit terminal 9, and
I through lighting switch, and body grounds E11, E22 and E53.
Headlamp RH relay is then energize
Old May 3, 2009 | 02:37 PM
n3985's Avatar
大陆弟弟
Does anyone know if the "FR FOG LAMP" 15A fuse in under the steering wheel is the correct one? Somebody must have blown a fog fuse and can tell me which one it is lol
And I couldn't find this "running lamp" either....
Old May 3, 2009 | 06:49 PM
DoubleOmax's Avatar
fog fuse is under the hood, driver side, the box just behind the battery. I changed mine before when i blew a fuse.
Old May 3, 2009 | 06:53 PM
n3985's Avatar
大陆弟弟
The 2 20A on the left side of the box or the 2 15A on the right? Thanks!
The Frye
Sep 2, 2021 11:03 AM
mvm062
Nov 30, 2020 09:00 AM
MaxLife17
Jun 27, 2019 01:37 PM
MaxLife17
Sep 8, 2015 02:36 PM
A32goldylocks
Sep 2, 2015 06:39 AM
