2002 Maxima SE MAF question
Old May 6, 2009 | 10:45 AM
Martin's Avatar
Does anyone know if the computer has to be re-programmed after replacement of the MAF, either new or used? The car is a 12/01 build date. Also, has anyone had a bad experience with an aftermarket unit. Speedycarparts.com has a good price on an aftermarket unit - $175. Nissan Canada wants $600.
Thanks in advance.
Old May 6, 2009 | 10:59 AM
tooreckless00's Avatar
To answer the first question, no you won't have to reset it. Once your replace the MAF turn the car on let it run for a few then shut it off. Repeat it again, and it will reset itself.
Secondly, if you have a stock air box try and stick with nissan.
Old May 6, 2009 | 11:38 AM
rroderiques77's Avatar
Demodded and Forgotten
Stay away from the aftermarket ones!!
Old May 6, 2009 | 12:24 PM
2kmax865's Avatar
Check out Dave B @ South Point. He has them less than $85. You can tranfer the resistor from old one. Beats over $400.
Old May 6, 2009 | 01:58 PM
spoolinmax02's Avatar
this maf works that they are telling you about i used it in my 02 max and it runs like a champ with no check engine light. installing the thermistor is really easy.
Old May 7, 2009 | 07:24 AM
Martin's Avatar
Thanks for your help everyone. I'm in the process of getting a replacement Maf.
Martin
Old May 7, 2009 | 01:58 PM
PeteusMaximus's Avatar
Martin
I have the $85 one with the thermister in it if you want to buy it.
$60 shipped http://forums.maxima.org/5th-generat...ssim-more.html
Old May 16, 2009 | 07:07 AM
Martin's Avatar
Peteus,
I will take your MAF.
Tell me how you want to be paid. Also, can I be sure your MAF will work on my car.
My max is 2002 12/01 build date.
Do you know the number - ie AM600, 6N200, 6N201? Is it in the tube or not?
Send me your info to:
martin@warning.ca
fastcarny
May 18, 2020 10:40 AM
fastcarny
Aug 12, 2015 03:50 PM
papo99
Aug 9, 2015 07:24 AM
yat70458
Aug 3, 2015 01:16 PM
