Clank, Tick tick tick, Blue Smoke. 2002 Maxima..What the...
Old May 14, 2009 | 05:20 AM
infinitiblast's Avatar
My wifes car is requiring at least 2 quarts of oil added in between oil changes. We dont have much money for any repairs, so I just keep an eye on it.
THis morning I go to start the car up and it sounds like a piston is flopping around in there, puffs of blue smoke billowing from the tail pipes...once the smoke stopped the idle and car cleared up. Just some valve ticking after that.
Without tearing the motor apart. I'm thinking I either have some serious blow bye issues, a leaking valve stem seal, or something else.
Just posting this for ideas....
Old May 14, 2009 | 01:20 PM
nismowolfe's Avatar
Im not sure what your up against but sounds bad sorry I couldnt help more.
Old May 14, 2009 | 02:30 PM
Blitzfist's Avatar
could be a blow piston ring...or worse. might be time for a new engine
Old May 15, 2009 | 01:23 AM
FlipCpt45's Avatar
Isn't blue smoke anti freeze / coolant?
Old May 15, 2009 | 01:55 AM
BronxSleeperMax187's Avatar
Bad gas maybe watered down causing knocking.... that model is known to burn oil like crazy try some better oil maybe too, are you always using 91 or better octane gas? ALSO MILEAGE?
Old May 15, 2009 | 05:33 AM
TheOnlyDRAGooN's Avatar
WHite smoke is generally engine coolant, black is carbon and oil. I think blue smoke is just a **** load of oil.
Old May 15, 2009 | 05:44 AM
Bassbreaker's Avatar
blue smoke is burning oil, hence adding 2 quarts between changes. White smoke is coolant(generally)...and black smoke is to much gas in the cylanders. I'm going to go with Blitzfist's post. That is a fair amount of oil to be burning. Make sure to use the highest octane you have at your station and try some high milage oil. Something a little thicker so it's harder to seep through a leak.
Old May 15, 2009 | 08:38 PM
chris in va's Avatar
Bent/damaged valve stem? Would explain the oil burning and ticking.
Old May 15, 2009 | 09:47 PM
MOB 02max's Avatar
sorry!
tarun900
19
Dec 20, 2021 06:57 PM
MaxLvr21
Oct 17, 2015 12:11 PM
Stagnet04
Oct 11, 2015 08:16 PM
BobTX10
Oct 7, 2015 08:43 AM
09maxshawn11
Sep 30, 2015 10:28 AM
