LED tail light resisters 2 green wires which one?
Old 05-16-2009, 11:33 AM
williamgd2's Avatar
I am trying to put in Led tail lights,I have read posts that say 2 resisters per tail light.One on the black and one on the green,But I have 2 green wires,I have green/yellow or Green/red can anyone tell me which green wire to put the Loader/Resister on?Thank you
williamgd2 is offline
Old 05-18-2009, 04:28 PM
williamgd2's Avatar
No one knows I guess.
Old 05-19-2009, 07:01 AM
cajun1104's Avatar
first off, what kind of loader are you using? I have led tails and only used one per tail. The wire that needs to be spliced into is the one to your brake light not the running light. just get a multimeter and find the wire that is hot with the running lights on and use the other one. hope this helps.
cajun1104 is offline
Old 05-19-2009, 08:15 AM
williamgd2's Avatar
Thank you cajun1104 That answers my question.I read on another post that peeps where using 2 resisters per light but I will try just the one on the right green wire.
Old 05-20-2009, 05:42 AM
Corelventura's Avatar
I would like to know as well which wire to splice with the load resistor as well ( i don't have the multimeter)
williamgd2, you mind post some pics of tail light after you done, thanks.
Corelventura is offline
Old 05-21-2009, 02:20 PM
scottygill's Avatar
Same problem here, i have green/white and green/yellow. To anyone who has installed the resistors, Id appreciate a headsup as to which green im supposed to be tapping into. ( I dont have a multimeter )
thanks in advance
scottygill is offline
Old 05-24-2009, 10:57 AM
scottygill's Avatar
which wires to hook up to the 6ohm loader
I just talked to cajun1104 and he said that the loader is hooked up to the black wire as well as the green/yellow wire (5.5 gen) i dont know about the red wire that was previously mentioned by william. Thanks cajun, ill take pics once i get mine hooked up.
tommy20020
01-06-2016 04:05 PM
4doorGTR
09-11-2015 04:09 PM
220k+ A32
08-17-2015 03:57 PM
Viralkill
08-17-2015 10:54 AM
Viralkill
08-16-2015 05:09 PM
Quick Reply: LED tail light resisters 2 green wires which one?
