Lights Out!!!
Old May 16, 2009 | 08:27 PM
Jreed2008's Avatar
Lights Out!!!
Well came 2 a stoplight and was sitting there then all my tach lights went out also ac lights and shifter lights. But stero remained on and my low beams and all other functions so to me that ruled out the battery but disconnected and retighten connections. Haven't checked all fuses yet but not really where 2 begin any ideas
Lights that are out:
Cluster lights except for gear display
Running Taillights
Ac lights
Shifter light
Parking lights
Fog lights
Old May 16, 2009 | 08:35 PM
scmax2000's Avatar
Running Taillights
Ac lights
Shifter light
Parking lights
Fog lights
Check the fuses........
Old May 16, 2009 | 08:38 PM
klemenz's Avatar
wow that's random. did any mods or electrical installations recently?
Old May 16, 2009 | 11:00 PM
zero2sixtyZ's Avatar
You embarrass me.
There should be a fuse that controls these lights. It happened to me, but I do forget which one. It should be either in the interior fuse box or the one right near the battery.
Old May 17, 2009 | 07:26 AM
Jreed2008's Avatar
Yeah just upgraded my power wire to 4awg and install a new sub. Was enjoying the fruits of my labor and this happened. But like I mentioned audio still works fine
yeah check some in cabin will checks others
Old May 17, 2009 | 07:52 AM
Metal Maxima's Avatar
SHIFT_om nom nom nom
Fuse #13 or #14, in the glovebox, second row, IIRC. Blew it a billion times working on LEDs.
If it's ont that one, it will be one of the rear taillamp fuses under the hood. I have no idea why in the hell Nissan put taillamps on an interior circuit.
Old May 17, 2009 | 08:03 PM
Jreed2008's Avatar
Bingo! Ur right it was the taillight fuse under the hood. Thanks sir
Old May 20, 2009 | 07:19 AM
Jreed2008's Avatar
Well replaced fused and the new one blew in a matter of minutes. So i guess I have to find the culprit Im assume it has to do with the Led Tails I had but removed and switch back and it still blew. Maybe Load equalizer is cause the problem?
Old May 31, 2009 | 09:33 AM
Jreed2008's Avatar
Ok I replaced the fuse and fixed the short. But my driver side parking light is still out from what I see there isn't a seperate fuse for the left parking light is there??
Old May 31, 2009 | 03:19 PM
ssaltzburg's Avatar
my dashboard light also went out and ac and gears also.. i have replaced all fuses any ideas??
Old May 31, 2009 | 05:08 PM
theKNICKSNY's Avatar
maybe a burnt ground wire?
Old May 31, 2009 | 08:20 PM
Jreed2008's Avatar
If your tailights are out like mentioned above than its the taillight fuse
fastcarny
Oct 6, 2015 10:42 AM
DarjeelingRose
Sep 15, 2015 01:20 AM
Maxie40
Sep 14, 2015 11:28 AM
-ReLLiK-
Sep 8, 2015 12:02 PM
Maxima30
Sep 7, 2015 06:13 PM
