Fiamm Highway Blaster Horns
Old May 17, 2009 | 08:46 PM
ridinwitha35's Avatar
Anyone use these? How did you get them to fit? I thought they were supposed to be a direct fit but they are too big to fit in that area. Also, does anyone know which metal piece is the positive/negative on the horn since you have to convert it to a single-wire setup?
Old May 18, 2009 | 08:33 AM
SurraTT's Avatar
HR Swap Pioneer
i have a mini air horn.
its like $40 50 at local autoparts stores
fits just fine...
and its pretty loud...
Old May 18, 2009 | 10:09 AM
MetaOrbit's Avatar
Got Projectors?
Ridin - keep in mind that the I35 has different, louder horns than those that come on the Maxima.
Any time I've changed a horn I usually just plug it up and see if it works (never changed them on my I35). Switch it around if it doesn't.
Old May 18, 2009 | 04:30 PM
Oh the I35 horns are different than the Max's? What do the Maxima horns sound like in comparison to the I35s, disregarding volume?
In terms of wiring, I tried both ways and the horn didn't work, so I dont know if I blew something if I connected it wrong one time.
Old May 18, 2009 | 05:27 PM
mist max2000's Avatar
i might be wrong.. but it think the way its wired.. they both need to be connected for it to work properly.. when i put my hella horns on.. i started with one and it wouldnt work because the other one was not connected......
Old May 18, 2009 | 05:37 PM
SurraTT's Avatar
HR Swap Pioneer
depending on what kinda horn you use. but most aftermarket LOUD one will draw way to many amps.
fyi i put a relay in myne. pulling power directly off battery..
otherwise it would honk for <5 sec then blow the fuse. which is SECURITY or HORN dependingn if its high or low tone.
Old May 18, 2009 | 10:04 PM
MetaOrbit's Avatar
Got Projectors?
They're weaker and IIRC have a higher tone. That's what I remember from my buddy's '02 GLE.
Old May 24, 2009 | 12:30 PM
It seems the right side horn doesn't work at all and the left side horn only works intermittently. It always works when I press on the horn on steering column, but say for example when I hit 'lock' on the keyfob; the lights blink but no horn.
This is making me believe the problem isn't the horns but maybe the relays or fuses. So I think my original horns may be ok but maybe the relays are bad. I will check.
Old May 24, 2009 | 02:32 PM
Woo hoo, fixed it!
So first thing I do is check the horn fuse...it was good. Then checked the 'anti-theft' fuse since I read some stuff about that having to do with the horns as well. It was good, however, there was a lot of green corrosion on it & the connecting terminals in the actual fuse box. I scraped off the corrosion, plugged it back in, and now BOTH horns work, even when doing a keyfob 'lock'. Beautiful, no need for new horns or relays!
So if anyone gets the intermittent horn problem, make sure your fuses & connecting terminals are clean!
Old May 25, 2009 | 07:25 PM
MetaOrbit's Avatar
Got Projectors?
LOL, I got the auto-notification email describing your problem and was just about to post what you discovered. Not long ago I had the same problem you were describing and noticed a lot of gunk/debris in the connectors. Cleaned those out and they were good. Unfortunately I had already purchased replacement horns, but they just went into another vehicle
Old May 25, 2009 | 08:00 PM
Same here, I bought the Fiamm horns already, tried to install one & it wasn't a direct fit so gave up with the intention on returning to it at a later time. Well, what a waste of $40 (especially since I lost the receipt though I only opened one horn up).
But at least my horns work. I just knew I had to do something when I hit the hazard button on the keyfob and all that happens is my lights start blinking.
Old May 25, 2009 | 08:07 PM
mannetti21's Avatar
Same thing happened to me awhile back...I bought a Stebel airhorn, the placement and install was horrendous, so I gave up for a few months until I realized I had screwed up the factory alarm horn. Now I'm blowing apart the hearing aids of those "top notch" elderly drivers
Old Oct 17, 2009 | 06:48 PM
rich5150's Avatar
So this is an old string, but can we get an update? I have an 03 SE, and want a horn, not a beep (stock). I have looked online and found horns for like $20 each. Anyone know where I can get a good loud horn cheap? Please post link.
Old Oct 18, 2009 | 09:20 AM
check ebay out... thats where i got mine.. 'hella supertones'
Old Oct 18, 2009 | 10:16 AM
Never installed the Fiamms. Matter fact I just threw them away since I couldn't return them.
1) since they wouldn't fit in my I35 without modification
2) because replacing the 'Security' fuse restored my factory horns
Old Oct 18, 2009 | 10:24 AM
6SPD02SE's Avatar
I have the freeway blaster horns you find at the auto parts store... i guess they are made by FIAMM. But i istalled them with no problem on my 02 Max. 1 connector has the pos wire going in and the other connector is for ground. It was a tight squeeze to get them behind the grill, but they fit nicely. Much better sound than the stock ear piercing horns.
Old Oct 18, 2009 | 11:14 AM
Professor's Avatar
I got the Hella Super Tones, There Ear splitting!
mclasser
22
Nov 12, 2020 01:58 PM
uttadms31
Sep 30, 2015 05:24 AM
salty318
Sep 29, 2015 01:21 PM
salty318
Sep 28, 2015 07:22 PM
