Whats wrong with my brakes?
Old May 21, 2009 | 11:59 AM
2damax's Avatar
Just noticed this morning at a slow roll i have a light metal on metal noise. seems to be from the left front tire. When I brake the noise gets much worse. No lights are on and I have not done any troubleshooting yet. Just looking for some thoughts.....Thanks for any help
Old May 21, 2009 | 01:23 PM
n3985's Avatar
大陆弟弟
The pads are prob nearing their end, time for replacement or you just need to clean and lube the anti-rattle shims.
Old May 21, 2009 | 06:30 PM
2damax's Avatar
Thanks for the reply...the pads probably do need to be changed but they never squeaked to much before and this problem is when I'm driving without the brake on. I looked a little closer and it almost seems the pad is rubbing the rotor at all times. IDK how to check if the caliper is stuck or not but since the noise gets worse when i brake its probably still opening and closing fine. How to I look at the anti-rattle shims and how do I lube them...thanks for the help
Old May 21, 2009 | 06:35 PM
VQP0WER's Avatar
Replace the pads. Most new pads come with the shims attached. Lube the caliper slide pins (the two you remove to remove the caliper).
Old May 21, 2009 | 07:02 PM
rroderiques77's Avatar
Demodded and Forgotten
Worn pads will cause noise with or w/o applying the brakes.
Change your brakes before you cause rotor damage.
Old May 21, 2009 | 07:20 PM
CMax03's Avatar
Check that the sliding guide pins are corrosion free, easy sliding and well lubed, check that the boots are in good condition and whether the piston is near fully extended! You should be able to press the piston back in with a C clamp, Open your bleed screws so you don't blow the seals in your ABS pump! Most calipers that are sticking are hard to press in even with a C-clamp.....Oh yeah change you fluid!
Old May 22, 2009 | 09:23 AM
2damax's Avatar
pads are being replace this weekend or next weekend....idk how old these rotors are so I think replacing them might happen (I'm hating the pulsing when I brake)
Old May 22, 2009 | 09:42 AM
n3985's Avatar
大陆弟弟
Just don't get OEM Nissan pads again, rotors just buy whatever is cheap and available.
Old May 22, 2009 | 05:12 PM
2damax's Avatar
yeah I'm thinking stock rotors if they need to be replaced and Hawk hps pads
Old May 27, 2009 | 09:37 AM
2damax's Avatar
alright so I had my mechanic change my rotors and pads. He said only the front had to be changed and the back have 10,000 miles more at least blah blah blah. Anyways, I never told him the noise was coming from the rear left tire and that noise is still there. If he said he checked and its fine, but the noise is still there, then wtf??
Old May 27, 2009 | 09:45 AM
jasonmax's Avatar
my stock brakes are nice and good, no viberation.
Old May 27, 2009 | 01:11 PM
2damax's Avatar
thats awesome. Why would a mechanic tell me nothing is wrong if he knows I'm going to pay him to replace it? I mean he has always been pretty honest with me but really? I can't stand the noise so I'm thinking of getting some money and just replacing them even though he disagrees
Apr 16, 2020 05:15 AM
BobTX10
Oct 7, 2015 08:43 AM
bigfrank
Oct 1, 2015 12:51 PM
leatherneck
Sep 30, 2015 09:16 PM
HerpDerp1919
Sep 29, 2015 02:02 PM
