$60 intake setup
Intake setup for $60
I had this setup for about A couple of months now and love it. Its very easy to do,and on the highway the car whips @$$...Also low end power is the same (tires spinning out like always) .. I went to autozone and bought spectre filter $20 bucks, Maf adaptor $10 or $15 I forgot, tube $20 and piece that hold tube to filter $5 for A total of $60 dollars the most.
First I removed the whole stock air box and maf sensor tube, then put the maf adaptor to maf tube, then the filter to the maf adapter, then the round piece that holds the tube to the filter on filter, then the tube to that piece and then took the tube and hooked it up from underneath to the stock piece as you can see in last picture=Perfect fit) Also taped up the hole from stock piece that you can see in third picture at end of tube. The reason I didint use that hole is cause tube wont fit to it so it had to be covered or else air would go tru it. Sorry for the cheap pics I will take some better pics soon and post.
Apr 16, 2020 05:15 AM
maxima297
Sep 30, 2015 03:32 PM
