Replacing Wiper Pivot Assy?!?
Old Jun 3, 2009 | 11:51 AM
nissandrvr98's Avatar
so monday it was pouring rain and i noticed while at speed the pass. wiper is no longer clearing the whole path and is actually sticking out from the windshield at an odd angle.
Stopped at T.Hill to check and the entire linkage feels sloppy vs. driver side.
The threaded arm the wiper bolts to which disappears under the cowl moves all around yet the wiper still moves with the driver side.
Anyone replaced this thing before?
Or better yet, even heard of this happening?
Old Jul 19, 2009 | 05:39 PM
bert's Avatar
Yep, sounds exactly like what I have. The wiper arm is solidly screwed to the pivot, but it is the entire pivot that moves, below the plastic protector plate.
I am thinking that there is poor drainage and at least one of the screws has rusted out.
Old Jul 21, 2009 | 05:52 AM
ha...actually all three of the nuts that hold the assy in place were missing! replaced, tighted and im good to go
Old Jul 21, 2009 | 06:45 AM
bert's Avatar
Is there all there is to do is remove the plastic cover over the pivot, once the wiper arm is removed?
Old Jul 27, 2009 | 10:53 AM
not sure i understand your question but to remove the plastic cowl (cover) there are a few plastic pop rivets (careful as they really fly out-i lost two). Once they're off you can pull the whole plastic cover off.
Start at one end and lift firmly as the rubber stripping has plastic clips that go sit inside it and clip into the metal frame of the car.
I stuck my fingers under the plastic, one on each side of the clip and thumb above it and gave a firm yank for each one.
Once its off you'll see the wiper assy and linkages-put together in reverse.
PH98I30
29
Feb 10, 2025 12:03 PM
mvm062
Nov 30, 2020 09:00 AM
dvcamp
Sep 18, 2015 10:17 AM
dcam0326
Sep 8, 2015 11:02 PM
Maxima30
Sep 7, 2015 06:13 PM
