How to install O2 SideSkirts on a 2k?.
Old Jun 5, 2009 | 12:05 AM
Ride2kMax's Avatar
I bought a set of 03 side skirts to put on and i was trying to figure how would they get install. Since the 00/01 dont have holes for the little pins that hold the rocker panel sides. I also notice that only in the front part of the car there are holes to hold the sideskirts.
So people who have done this can you guys tell me how you did it and if you took them to a shop to get them install how much did you pay. I want to know how much should i expect to pay for a shop to install them.
Thanks everyone for the help in advance.
Old Jun 5, 2009 | 01:20 AM
DrunkieTheBear's Avatar
Turbo'd Saab
The sideskirts mount under the door, don't push it up under the crack between the door and the frame.
On either end of the sideskirt there are holes, 2 in the rear 3 in the front, they line up with the holes that were made for the mudflaps, once you have that, it should mount up easy. I went to a hardware store, bought self tapping screws, 1" long with washers and just drilled into the tabs into the frame of the car. It took about 20 mins each side.
Old Jun 5, 2009 | 05:38 AM
Lontar1's Avatar
Puerto Rico-Maxima Lover
I did the same but w/o drilling, the front and back screws should be enough to hold them in place.
Old Jun 5, 2009 | 05:47 AM
Augustus Maximus's Avatar
post some pix when you get it done.
Old Jun 5, 2009 | 06:30 AM
secondtonone317's Avatar
nycnissans
this is a simple thing to do, when I had 02-03 skirts I just screwed it up on the front and rear and I think I ran a few screws from under on the tabs
Old Jun 5, 2009 | 08:44 AM
DrOmed's Avatar
I had to run a strip of 3m double sided mounting tape along the entire length of the top of the sideskirt to hold the top end from separating from the car. It looks good now, but before (and since we can use the clips to keep it tight to the car) the rocker panel(which is the official name for the 'side skirts') looked like they were coming off the car. Now they are stuck on real tight and they look great.
DrOmed.
P.S. Make sure you use the wide (about 1/2 inch wide) tape. The thin one does not do a good job of holding the panels in place.
Good Luck.
Old Jun 5, 2009 | 09:08 AM
Grand_hustle17's Avatar
doesnt matter what size tape you use its ultimately simple... just use drill two screws through the wheel fender in the fron and rear and just for assurance if u want, one in the middle of the lip where the front and rear doors are, u can use 3M also thats fine, doesnt really matter how much u use
finished product on my 00 GXE
and i didnt even use that much 3M
Old Jun 5, 2009 | 09:52 PM
Ride2kMax's Avatar
Thanks guys I was worry thinking i had to drill holes all around the sides.
If have a shop do it how much would be a decent price to pay.?
If i put them on i'll post pictures.
Thinking that needed to drill holes on the sides i put them for sale on the for sale section.
I will take them down.
Thanks everyone.
Old Jun 6, 2009 | 08:50 AM
u can just sell em to me lls... no need for a shop, if i can do it a sensless dummy can (yep thats how i feel ) if a shop does it they'll probebly charge u for an hr's work when its really about a 1/2hr... if u was in MD i'd do it for ya for lil or nothin
Old Jun 6, 2009 | 09:11 PM
Ride2kMax's Avatar
The only reason im thinking about taking them to a shop is because they are silver my car gold and I dont know how paint them.
Old Jun 7, 2009 | 01:33 PM
get em painted before you install
Old Jun 7, 2009 | 08:10 PM
s1mply_v's Avatar
I went the whole 9 yards and drilled holes for push tabs on the inside of the 02 sideskirts, then the obvious front and rear screws, but just skipped screwing the tabs on the underside because i was scared they'd rust alot faster.
Old Jun 8, 2009 | 07:30 PM
rust... u did all that and just stop because of something u thought would happen.................................... i didnt even use the push tab blah blah's... i use some black drywall screws that i took from my work truck and just drilled in the frame... believe me ppl, its not that much to it as you guys are thinking... it really isnt... its a very simple task (and when me... Grand_hustle says something about a car is simple... it's really simple)..... this is all coming from a guy who installs nothing on his car... not intake, not block off plate, not even my 8K d2r bulbs, but this one was too easy
MaxLife17
Jun 27, 2019 01:37 PM
Excalibur23
Oct 13, 2015 04:33 PM
Max8
Sep 22, 2015 02:53 PM
2kmaximel
Sep 16, 2015 03:19 PM
Johnny9595
Sep 3, 2015 05:18 AM
