Reseting the ECU on a 2k2 MAX
Maxima.org Sponsor and Donating Maxima.org Member
I'm just wondering for future reference how you reset the ECU on a 2k2 maxima. I'm gonna be doing some mods and such and i want to know how to reset it. and before someone says it, the leave the negative battery cable off trick DOES NOT WORK.
Re: Reseting the ECU on a 2k2 MAX
try leaving it disconnected overnight. that's what I did and it took care of it. If it doesn't work ... then it makes sense that whatever set it off the first time is still present and needs to be corrected. Unless they have done something different in the 2K2 models that trick should work. And like I said before ... if it doesn't that means that whatever set it off needs to be corrected ... meaning a more serious problem.
PCGuRu2K light came on and after disconnecting the battery it came back. He found out that and O2 sensor was bad on the front bank. Well you don't really want your ecu to disregard that do you!
Re: Re: Reseting the ECU on a 2k2 MAX
Originally posted by PhatGuy
What mods are you going to do? To date what mods are available for the 2K2?
oh man, someone here should do this to their MAX...
http://www.alpha-armouring.com/
"Go ahead, make my millenium"
Originally posted by PCGuRu2K
Anyone know how much I will be expected to get charged if they do decide not to do it under warranty?
My Bank 1 O2 Sensor is indeed bad. I'm gonna have to take back to the dealer sometime this week to have it serviced. Hopefully they'll do it under warranty, dunno if they will since they'll see my CAI installed. I don't have my stock box anymore, can't find it. Anyone know how much I will be expected to get charged if they do decide not to do it under warranty?
they can't charge you for the O2 sensor just for having a CAI. if you had a y-pipe then they could, but the CAI will not void any part of the exhaust warranty. if you needed an MAF they could refuse but not an O2 sensor, don't let them make you pay for it.
Originally posted by Garfield
hey..seem like disconnect 3 hrs is not enough ...
how do u know the ECU had beem reset?
According to the manual for the 4th gens it takes 24 hours to reset the CEL light. I did this for my 5th gen and it worked. I let it sit for 24 hours, I don't know if you could get away with less.
so you have to leave the batttery disconnected for 24 hours ?!?!?!?!!?
How do you know it worked for sure unless you scanned the ecu right afterwards?
You won't unless you get it diagged at a shop. Mines went away, came back, went away, and now its back again. Gonna take it to the dealer tomorrow to replace my o2 sensor..
After 24 hours the ecu is reset, no fault codes. If you have a continuing problem, the codes will reappear.
Resetting the ECU can be done by removing the negative battery cable. On ANY car. The only problem is you have to leave it off for about 15 minutes. The PCM <----what its really called has memory, and the only quick way to clear the memory is to actually press and hold the brake pedal to clear it out. You only have to hold the brake pedal for about 30 sec.
Omar Abdurrahman Siddiqi
08-26-2016 05:18 PM
220k+ A32
09-22-2015 03:08 PM
QueensMAX
09-15-2015 04:14 AM
