Megan Racing Springs. serious drop...
Old Jul 10, 2009 | 09:16 AM
Foellarbear's Avatar
Ok so everybody is tellin' me that i need a serious drop with the 20's im throwin down on my maxx. So i have about 110,000 on my ride and im assuming not only am i gonna need springs but new struts cause they are gonna blow. With 20's i think i wanna go about 1.75 in the front and 1.75 in the rear... does anyone recommend any other height adjustments for 20's? also what brand and where do you recommend getting new struts if i need them?
Old Jul 10, 2009 | 09:36 AM
phatboislim's Avatar
i have dropzone springs with tokico illuminas which offer 2" drop....the drop is ok...i just wish, because of what i want to do with this car, that i purchased the coilovers i was set on.
i love my struts, not so much the springs. when i redo my suspension i'm getting Tein SS Coilovers
here is a pic on my stock wheels w/ the 2" drop
Old Jul 10, 2009 | 12:05 PM
ok will a 2 inch drop though work with some 20's? im kinda worried about that... and ya im lookin at around the same setup as yours... not really interested in coilovers. waaay too expensive. but how much was your suspension setup? Thanks.
Old Jul 10, 2009 | 12:23 PM
PulsarGTS's Avatar
As long as you have the proper tire size, your 20" rim/tires combo is no bigger than stock. The tires are lower profile to fit the larger rims, so the overall height is not effected. A 2" drop with springs will ride harsh over bumps because of the limit travel on maximas and your super thin tires.
Old Jul 10, 2009 | 12:29 PM
ah.
k thanks for that. Im probably not gonna go with a 2" drop, probably 1.75" in the front and rear. I can already feel the road wit the low pro's. but i guess that sounds about right....
Old Jul 10, 2009 | 12:44 PM
nismowolfe's Avatar
someone on here had infinity 20s with tein stechs and I beleive they go even lower than 2 inchs of drop and were ok. If your that person please chime in.
Old Jul 10, 2009 | 12:55 PM
M1RAG3's Avatar
get tein s-techs...2.2inch drop in the front and 1.6inches in the rear. As long as you are running 35 series or lower rubber on the 20s you should be fine (unless you have 255 width or larger tires in which case you might need your fenders rolled)
Old Jul 10, 2009 | 09:45 PM
ok...
mmhhmm that sounds real good. where can i get these springs? and also i need some struts so they don't blow... where can i get those too? will i need spacers?
Old Jul 11, 2009 | 02:12 PM
4th4Lyfe's Avatar
I am rolling on Tein S-Techs with KYB Gr-2's and the ride is fine to me. I went with the S-Techs because I always see people that wish they were a little bit lower than a 1" drop. My recommendation will be to go low so you have no regrets.
Old Jul 12, 2009 | 06:41 AM
Majestic Ken's Avatar
yea its all in the tires. I'd go 225/35/20. when i had 20s i had 245/35 and it stood the car up from the ground, but still looked dropped from the fender wells. if you want to do a 30 series get a name brand tire so they wont pop as much if you have major potholes
Old Jul 12, 2009 | 08:51 AM
ya well im good here on brand name. no cheap tires here. Got some Nittos for $100 a piece.
Old Jul 12, 2009 | 09:38 AM
CMax03's Avatar
Progress are 1.75" drop in the front and 1.5" drop in the rear but maybe to soft for all the weight! Definitely invest in some illuminas or some other heavy duty strut assys.
Old Jul 12, 2009 | 10:02 AM
get on one of those tire calculator sites and play around with tire sizes. compare the size of an 18 inch wheel with tire to your 20s with a tire and go from there. my homeboy used to have 225/30/20 and eibachs and he sat LOWER than me with progress springs with 245/40/18's.
Old Jul 12, 2009 | 10:23 AM
MOB 02max's Avatar
so is megan racing springs any good with stock struts?
Old Jul 14, 2009 | 08:47 AM
i'd assume they are pretty good. you can get them for a pretty decent price on ebay.
Old Jul 14, 2009 | 08:52 AM
if its for DD...i see no reason to get any kind of springs...ur just gona have to worry about the ride...struts can compensate alot for bad springs
Old Jul 14, 2009 | 11:51 AM
woody6212's Avatar
I got an 01 Se with 20" wheels on there with H&R springs and stock struts. No rubbing issues and the ride was great for awhile but, ya everyone is right you need to get struts pretty soon after the springs. I'm considering doing coilovers in the front and illuminas in the rear simply for the same reason as stated above I would like a little adjustability in the front. The rear sits pretty but I would like to see a little lower in the front.. But H&R's ride great and has no rubbing with 20s..
litch
123
Jan 4, 2024 07:01 PM
imported_Nismo_max
Feb 17, 2016 03:39 AM
followthadollar
Sep 23, 2015 08:31 PM
