Check engine light was removed from 5.5 gen
Old Aug 9, 2009 | 08:06 PM
wish2345's Avatar
i noticed that my CEL didnt even come on when i first turned the car on so i took the cluster out to check it out and it looks like that bulb is soldered in. Well there is no bulb in that slot so one of the previous owners must have taken it out. Is there any way to take the face off and get a new bulb soldered back in?
Old Aug 9, 2009 | 08:14 PM
nsnrider's Avatar
FAIL, 5.5 gen clusters don't have a bulb for the CEL, its an LED. I just checked.
turn over key in ignition to ON but don't start car, light should lit up.
Old Aug 10, 2009 | 06:49 AM
wish2345's Avatar
yes i know its an LED and not a twist out bulb. someone took the LED completely out and i need to get one soldered back in i guess
Old Aug 11, 2009 | 06:18 AM
daredevil514's Avatar
Thats not a bad idea... hahaha
Old Aug 11, 2009 | 08:13 AM
Nelsito65's Avatar
If you haven't done so, you might want to scan your car for codes. There is a reason why people remove those bulbs/LED's. When I discovered that the SES bulb was removed in my car too, soon after I bought it, I had 1 stored code that was not giving any wanrning to potential buyers, including me.
Old Aug 11, 2009 | 08:17 AM
fflint_18's Avatar
Even worse, in New Jersey you can't get through inspection unless yopu have a working light.
They want to make sure you're not doing exactly what was done to you.
Good luck and hopefully the codes aren't too bad.
take it to Autozone. They will usually run the codes for free.
Old Aug 11, 2009 | 08:19 AM
wish2345's Avatar
i am not worried about getting codes from the car as i have a scanner. i just want to get the SES light bulb back in there like it should be . How can i do this ?
Old Aug 11, 2009 | 08:32 AM
Nelsito65's Avatar
Hopefully someone will chime in with some help on how to do that. Mine is a twist out bulb.
Old Aug 12, 2009 | 10:59 AM
wish2345's Avatar
i know someone has had this issue and got it fixed
Old Sep 4, 2009 | 09:07 PM
wish2345's Avatar
anyone?
Old Sep 5, 2009 | 12:57 AM
HotshotVQ35's Avatar
put the led back in?
Old Sep 5, 2009 | 01:33 AM
Gemner's Avatar
I would guess you need to obtain the led and now solder it in
Old Sep 5, 2009 | 05:16 AM
CustomLowz's Avatar
I don't know if you can just get another LED and solder it back in, but I am thinking more that you will need to replace your entire cluster.
Old Sep 5, 2009 | 07:16 AM
Ghost_54's Avatar
Finding out the exact size of LED and if a resistor is required, again what size is going to be the first questions. I can provide you with two links from fellow members that have made conversions within the cluster. The first link is for converting the main led's to blue within the cluster by knight_yyz (I would PM him to ask more questions with regards to the led required, as he seem to have some pretty good knowledge on this).
http://gtamaxima.darkbb.com/5th-gen-...t_yyz-t278.htm (knight_yyz is also a member on this site)
The second link is for a How To Do removal of the main cluster its self, this write up was for installing chrome rings, but it has all the step by step removal process to access the main cluster, so it to should be helpful (this was written by Will and is safely stored on the backup site for TMEC)
http://gtamaxima.darkbb.com/5th-gen-maxima-2000-2003-f4/chrome-gauge-ring-and-or-gauge-leds-install-00-03-max-written-by-will-t295.htm
(Will is also a member on this site, sould you have additional questions)
Old Sep 5, 2009 | 07:34 AM
Professor's Avatar
Its very easy, i converted mine to led, Just whatever you do, DONT remove the needles. its all done from the back, you just have to take out every single screw, theres alot. buts is very easy, with LEds you have to make sure the polarity is correct. you basicly see then once you take it all out
POLARITY
Old Sep 5, 2009 | 08:22 AM
Child_uv_KoRn's Avatar
Bad *** Newb
Why are you complaining, this is a 5th gen dream LOL
Old Sep 5, 2009 | 12:41 PM
SteveB123's Avatar
Not sure how a broken car can be a dream, but whatever floats your boat, I guess.
Old Sep 5, 2009 | 01:39 PM
CustomLowz's Avatar
I think he meant because there is no check engine light
Old Sep 5, 2009 | 01:41 PM
jasonmax's Avatar
no light for 2 years. maybe I'm lucky
Old Sep 5, 2009 | 02:08 PM
Grand_hustle17's Avatar
i had my CEL off and i got it checked to make sure there was no codes lls, no CEL is foreign to me
Old Sep 5, 2009 | 03:33 PM
knight_yyz's Avatar
Toolie
that board is not going to help the OP as he has a 2k2. I have a spare board for a 2k3 or 2k3 auto.
The 2k2/3 board uses smd's not led's
you can buy smd's on ebay, but again polarity is important so if you solder it on backwards you are out of luck.
There is a way to remove the needles which will not screw up calibration, not sure if it is on this site or not, but it is on the G35 driver site.
Old Sep 5, 2009 | 03:41 PM
Professor's Avatar
God smds suck lol but yeah you can use a standard led in place as long as theres room just slap on a new smd you can get at radio shack.
Old Sep 5, 2009 | 03:55 PM
Bad *** Newb
My sidemarker bulbs disagree
Old Sep 5, 2009 | 04:54 PM
Professor's Avatar
Lol yeah I have 5 smd led lights in each plate light housing, there nice but if they burn out there bleh
Old Apr 28, 2010 | 06:46 AM
jroy3221's Avatar
cel codes p0140 and p0430
Hi everyone, since i got my hks catback exhaust, stillen y pipe my 02 sensor have been displaying p0140 and p0430 codes. Any ideas of what it could be? thanks in advance.
Old Apr 28, 2010 | 07:25 AM
merovi's Avatar
P0140 – Heated Oxygen Sensor malfunction Sensor 2 Bank 1
P0430 Catalyst System Efficiency Below Threshold Bank 2
Next time just go to autozone and they do the same for free.
Old Apr 28, 2010 | 07:32 AM
Rochester's Avatar
That was awfully nice of you, Ryan, directly answering a noob resurrection of a 7-month old thread for a completely OT post. Most people would ignore or flame.
Old Apr 28, 2010 | 07:47 AM
Scottwax's Avatar
That's Mr. Detail to you
I can pretty much promise you both precats will need to be replaced to clear the codes.
Old Apr 28, 2010 | 08:02 AM
merovi's Avatar
My response started as a go to autozone flame, but this just ended up being easier. Kills me because there are 1000's of topics that directly address his issue yet he resurrects a un related thread.
Old Apr 28, 2010 | 08:03 AM
merovi's Avatar
I smell a "buy headers" answer soon.
Old Apr 28, 2010 | 01:40 PM
Scottwax's Avatar
Before buying headers, I'd buy O2 sims to make sure they are going to work for your car. Would suck to get headers, then get O2 sims to pass emission testing and not be able to get them to work.
Finkle
Sep 27, 2015 09:53 PM
tcb_02_max
Sep 11, 2015 12:23 PM
beboski
Aug 16, 2015 05:23 PM
MaxStock
Aug 14, 2015 10:03 PM
MaxStock
Aug 12, 2015 08:33 AM
