Tranny Problem...
Old Aug 27, 2009 | 11:37 AM
Tee00Max's Avatar
Tranny Problem...
Recently my tranny has been slipping bad when it shift from 1st to 2nd but the other shift are very smooth but its bothering the hell outta me with 1st to 2nd, So I just walked in the door from changing my tranny fluid, I drained it out the pan and put 4 quarts back in there hopped in it and it was basically feeling the same way. Any suggestions on what it could be, i hope its not my tranny need rebuilding or anything. Advice welcome.
Old Aug 27, 2009 | 11:46 AM
Love_00_Max's Avatar
Pl. provide the following
1) Maintainence history
2) Num of miles before changing fluid
3) Kind of abuse/pampering it has recieved over the years (if you are the only owner/driver).
Old Aug 27, 2009 | 11:49 AM
Tee00Max's Avatar
1) Never did any work on the tranny
2) When i got the car it had about 83k miles on it, I prob didnt change the fluid till about 120k maybe.
3) I hit it every now and then, went to the track once.
Old Aug 27, 2009 | 11:52 AM
omartopsecret's Avatar
what kind of trasmission oil did you use? was it for inports
Old Aug 27, 2009 | 11:53 AM
Tee00Max's Avatar
yea castrol for imports...black bottle
Old Aug 27, 2009 | 12:01 PM
you shuld put lucas trasmission additive i got this from their website.
Lucas Transmission Fix
Lucas Transmission Fix is a non-solvent formulas that stops slip, hesitation and rough shifting in worn transmissions and completely eliminates most seal leaks. Use in any transmission for preventative maintenance.Use also in light duty manual transmissions to increase shifting ease and transmission life.
Key Benefits
  • Contains no solvents
  • Lowers operating temperatures and stops foaming
  • Can be added to existing fluid without draining any out
  • Effective in an extremely high percentage of cases
Old Aug 27, 2009 | 12:03 PM
Tee00Max's Avatar
Key Benefits
I heard alot of people say that they dont like putting additive in their cars but if its helps then i dont mind putting it in there but i want more advice to see if it really helps.
Old Aug 27, 2009 | 12:05 PM
every time i change my motor oil or transmission oil i put lucas sorry for the transmission misspell lol.
Old Aug 27, 2009 | 12:09 PM
Tee00Max's Avatar
lol i knew what you mean and yeah i also use it in my motor oil but i have never used it in my tranny. But if its helps i will def roll outta here and go to advance and get some.
Old Aug 27, 2009 | 12:17 PM
yeah lots of people dont like tu put additves and allsow change there transmission oil becuase they say it will mess it up, what hapens is that they put the wrong oil, i say it never hurts to tray
Old Aug 27, 2009 | 12:27 PM
yeah but i have to correct myself becuase we have lots of english teachers here that are allwey correcting me, lol my writing is no that good for starters lol. hope that it helps you good luck
Old Aug 27, 2009 | 12:39 PM
Tee00Max's Avatar
yea i might get some and see if that helps...thanks for all your input.
Old Aug 27, 2009 | 12:44 PM
First off you dont put any damnnn additives into the tranny. Take time to understand the problem vs putting some OTC additives......
Looks like it needs a drain/fill to begin with. Castrol MV import ATF is good ATF for a bargain price... I will do quick drain/fills to be sure the old ATF is out.
Old Aug 27, 2009 | 12:50 PM
Tee00Max's Avatar
yeah i think thats what i put in there i just drained it i didnt do a full flush....
Old Aug 27, 2009 | 01:11 PM
yeah buddy he said that and i quote "I just walked in the door from changing my tranny fluid"
Old Aug 27, 2009 | 01:39 PM
Tee00Max's Avatar
Old Aug 27, 2009 | 01:41 PM
i was talking to love_00_max lol sorry
Old Aug 27, 2009 | 01:42 PM
Tee00Max's Avatar
o ok i see now...lol
Old Aug 27, 2009 | 02:03 PM
Tee00Max's Avatar
any other advice from anyone else?
Old Aug 28, 2009 | 01:38 PM
Tee00Max's Avatar
bump....
Old Aug 28, 2009 | 04:27 PM
SurraTT's Avatar
HR Swap Pioneer
change the transmission filter?
get it flushed at a shop?
Old Aug 28, 2009 | 04:51 PM
Tee00Max's Avatar
Thats my next move and then i will go from there. Where can i get the filter from? Can I get it at a parts store or just Nissan?
Old Aug 28, 2009 | 04:58 PM
SmokinMax02's Avatar
TCM
You need the updated version...
Old Aug 28, 2009 | 05:09 PM
Grand_hustle17's Avatar
hit up car-parts.com for a tranny and build the tranny, probebly add a high stall TQ and the transgo shift kit if u drag
Old Aug 28, 2009 | 05:44 PM
Why would he do that when all he needs is the updated TCM?
This isnt a new problem for A33 auto trannies. Thats why there's been a TSB on this exact problem for quite some time now.
Old Aug 28, 2009 | 05:50 PM
Tee00Max's Avatar
so all i need is the updated TCM??
Old Aug 28, 2009 | 06:00 PM
By the symptoms you're describing, yes.
However, the updated TCM isnt cheap IIRC. Will run you around $350-400 through DaveB.
Old Aug 28, 2009 | 06:03 PM
Here is the # if you need it...
1-888-254-6060
Ask for Dave Burnette and tell him you're a member of Maxima.org, he will work with you on a fair price.
Tee00Max's Avatar
smh, i swear if its not one thing its another. The one the guy is selling in the 5th gen classifieds is not the updated one or what?
Old Aug 28, 2009 | 06:25 PM
Link?
I know there was a member on hear that was trying to sell an updated version awhile back.
His user name was "unrealii". Perhaps send him a PM?
Old Aug 28, 2009 | 06:47 PM
Tee00Max, honestly u are getting BS advice for folks talking about filters/TCM etc.
There is no filter in our trannies, it is a screen. If you know by now there is a bolt on the screen, it is almost impossible to get to, so quit thinking on those terms.
TCM has been a issue on 00-01 trannies only if you abuse it. U won't find a whole lot of hits on this forum/google on JATCO trannies. So stop chasing a ghost.
Do drains/fills and keep the tranny happy.
Old Aug 28, 2009 | 07:05 PM
This is bs.
You admit the TCM has been an issue for A33 auto's (00-01's), but you automatically chalk it up to "only if you abuse it"?
Then why is there a TSB for TCM's in 00-01's?
How could you possibly know that all problems with the TCM occur as a direct result of abuse, even though there was a TSB for it?
You couldnt.
Anyways, I'll dig them up when I have more time, but there are several threads and posts that directly point to the 1-2 slips as a result of a TCM, not to mention TSB's.
Old Aug 28, 2009 | 07:25 PM
Old Aug 28, 2009 | 07:30 PM
Original TSB, describing the exact symptons TeeMax is describing....
http://maxima.theowensfamily.com/tsb/NTB00-039a.pdf (TSB)
http://forums.maxima.org/5th-generat...-properly.html
http://forums.maxima.org/5th-generat...py-my-car.html
http://forums.maxima.org/5th-generat...rebuild-2.html
http://forums.maxima.org/5th-generat...cm-recall.html
If its not the TCM, then shift solenoids or valve body would be your next step.
Old Aug 28, 2009 | 08:48 PM
My take on this is do drains/fills and see if that changes the behavior. All the parts documented for folks here are not cheap, they can easily take the bill to $1000 even if you replaced it yourself (add another $500 if you are going to give it to the stealership not knowing if they replaced the part of not, they may just wipe the mapping and put in factory fix to make it look like it is all BRAND new).
It isn't worth it when the car is 9 yrs old and could be worth less than $5000.!!
IMO pushing out the inevitable by doing drains/fills is a better option than putting in so much money into it. If the car ran for 125K on a faulty VB, solenoids, TCM or whatever, the probability of extending its life futher is shortsighted.
BTW, I have 3 friends (4 of us together graduated with MSEE) and bought maximas. We kind of all liked and fell in love with our maximas. All my friends traded in their maximas before 125K miles and moved on and they all complained about the trannies, P1320 etc., they would occasionaly abuse the tranny. They never changed the tranny fluid, I kept doing drains/fills and flushes and I have racked up 168K miles on my tranny. JATCO trannies are know to be of solid engg and they may not be perfect but then what is perfect in this world. My 2006 highlander tranny shifts like POS, my wife is scared out of her mind with the hesitation, go look up on google u will see 1000000s of posts on this specific AW tranny but on the same note you will not see failures. How am I going to get the best out of it, drain and fill every year?
So start with drains/fills and see how that goes before dumping a lot on money on it.
Old Aug 29, 2009 | 01:41 AM
yeah that bolt that love_00_max is talking about is a pain in the *** to take off you need a impac gun to take it of ok or a drill gun, make sure to clean you oil pan to. you could buy a transmission oil filter in any auto parts.
Old Aug 29, 2009 | 10:09 AM
unrealii's Avatar
I heard my name Let me know if I can be of any assistance. I do have a TCM for sale purchased from Dave B. It did not solve my problems because my car isn't flaring. My vin# also falls outside of that TSB period.
Old Oct 21, 2009 | 07:39 AM
mandyfig's Avatar
For a 2000 Max with Auto tranny, how many quarts are drained? Thanks.
MaxStock
Dec 5, 2016 05:19 PM
fx4five
Oct 18, 2015 06:57 PM
fx4five
Oct 1, 2015 04:58 AM
pktaske
Sep 4, 2015 08:40 AM
Lowered_a33
Sep 1, 2015 07:49 PM
