How to bypass BOSE???
Old Sep 9, 2009 | 09:36 AM
tbaGd_jEw's Avatar
Here's my issue...I have a Pioneer headunit in my car with the rest of the audio system being the OEM Bose. I can turn the volume up to about ten with the volume increasing, but after that only the numbers will increase and not the volume. I was told that the easiest fix is to completely bypass the Bose system...is this the case? If so, could someone maybe point me in the right direction. I have looked for a right-up on this, but have been unsuccessful in finding one.
Old Sep 9, 2009 | 12:16 PM
Progress's Avatar
It's business time.
Do you have a PAC-OEM adapter installed?
Old Sep 9, 2009 | 12:35 PM
nismowolfe's Avatar
Yeah if you have the adapter the gain controls on the adapter can be turned up and this will make a huge difference.
Old Sep 9, 2009 | 12:43 PM
MoncefA33's Avatar
What wire harness are you using?
You could also try the Metra 70-7551.
Old Sep 10, 2009 | 11:47 AM
dnozzle2789's Avatar
if you want to bypass the bose, then i assume you mean you want to bypass the bose factory amplifier. get a 9 wire and then buy a 4 channel amplifier. take out the factory speaker wires out of the bose amp, (located in trunk under rear deck) attach to 9 wire (or not. your choice) and run into 4 channel amp. or you could do that with you're pioneer headunit amp instead of getting an external 4 channel.
basically what im saying is take the factory speaker wires out of the factory bose amp, and run them to some other kind of power source - like your pioneer headunit (internal amp) or a 4 channel
Old Sep 11, 2009 | 04:46 AM
tbaGd_jEw's Avatar
Sounds like a real ***** to do. Yeah, I'm not really sure which wiring harness I'm using.
Old Sep 11, 2009 | 04:50 AM
tbaGd_jEw's Avatar
Also, what is this PAC adapter thing, and how does it work?
Old Sep 11, 2009 | 06:10 AM
TallTom's Avatar
you can use something like this, but your headunite needs to have 4volt RCa outputs or the volume will be low:
http://www.sonicelectronix.com/item_...mpaign=froogle
Or, like the guys mentioned, get one of these and set the gains:
http://www.sonicelectronix.com/item_...AOEM-NIS2.html
Old Sep 11, 2009 | 06:58 AM
bigpopaj369's Avatar
or u could just get new speakers install them and run new wires and power them off the HU, leave all the old wiring there and switch it back to bose when u get a new car or upgrade
chisam14
Nov 6, 2018 08:56 PM
Fbana41
Aug 29, 2016 12:18 PM
sliptap
Sep 30, 2015 05:57 AM
Redfox
Sep 28, 2015 10:41 AM
Kyle Lee Cleveland
Sep 28, 2015 09:03 AM
