Clutch on the way out?
Old Sep 18, 2009 | 04:21 PM
viperboy's Avatar
Hey guys I posted this in the general maxima discussion but now I think it would be better to put here. I'll just quote the info from that thread here...
Never kept a car long enough to know the signs, but it feels like the engagement point is moving up and it doesn't seem to be grabbing like it used to. Could it just be the linkage is out of adjustment or something? Thanks
Drove back from philly and it is definitely engaging alot later. If I redline it and shift, it grabs and doesn't feel like its slipping, but its not grabbing as fast as it used to.
I'm taking it to the shop tomorrow. Anything that is common on the 5.5 gens in regards to the clutch? A possible cylinder problem maybe? I guess at this point it would be better to post this over in the 5th gen section...
Hoping for some good info on this. Thanks!
Old Sep 18, 2009 | 05:27 PM
anomaly117's Avatar
a good way to check is to put it in 5th (or in your case 6th i guess) at around 45 mph, and step on it, if the clutch is slipping, the RPM's will climb but your speedo wont.
Old Sep 18, 2009 | 05:32 PM
viperboy's Avatar
Well, 6th gear at that speed is around 1500rpm, I wouldn't wanna punch it there. But maybe 4th around 40 would be good. That's about 2100rpm. But I did hit it in 2nd from about 3k to redline and I didn't notice any slipping.
If it doesn't slip, what else could it be? What else explains the clutch not grabbing and the engagement point moving up on the clutch pedal??
Old Sep 18, 2009 | 06:03 PM
Derrick2k2SE's Avatar
You can adjust the pedal travel with the threaded rod that connects the pedal to the master.
The pedal travel will move up a bit as the clutch wears. That's probably what you're feeling. Most other problems will cause the engagement point to be closer and closer to the floor till you can't push it in far enough to disengage.
If you want to check for a slipping clutch just try to bark the tires. If you can bark them you're pretty good. Usually when they first start to slip it will only be noticeable when taking off and shifting. By the time you can get it to slip while it's already engaged it's pretty bad and your flywheel is probably toast.
Old Sep 18, 2009 | 06:22 PM
viperboy's Avatar
I'll give that a shot! thanks!
The thing that gets me though is that I swear it didn't act like this before I left! I'm really hoping that its an adjustment or fluid thing!
If not, I guess I'll have to do a Fidanza FW and a 350z clutch. On that note, does the 370z clutch work in our cars??
Old Sep 18, 2009 | 08:07 PM
viperboy's Avatar
Went out tonight and did the 1 to 2 test and it held just fine. Also held when I was in 4th at 40 and got on it. Ran with a couple people tonight and no problems. It is definitely engaging later so I hope its just out of adjustment.
Old Sep 18, 2009 | 08:44 PM
QNO_A32's Avatar
is the adjustment similar to a 4th gen anyone know?
Old Sep 18, 2009 | 09:18 PM
P. Samson's Avatar
As already explained to you above, clutch engagement will occur higher up with the normal wear of the clutch friction material. It's just simply a fact of life. The master cylinder (piston) pushrod adjustment is for obtaining the correct pedal freeplay adjustment only, NOT for adjusting the engagement point. If you lengthen the pushrod in a misguided attempt to "adjust" (lower) the engagement point you'll end up eliminating the pedal freeplay and probably cause a premature failure of the release bearing (because the bearing will be loaded/spinning all the time). (The normal, correct pedal freeplay is "about" 1/2 inch).
Old Sep 18, 2009 | 09:38 PM
This is very true. Any adjustments you make to it should be small and always check for proper freeplay.
Old Sep 19, 2009 | 04:23 AM
viperboy's Avatar
Thanks for all the great info as always, guys.
The only thing I can't figure out, is why this started to happen after I let the car sit for a week. It never did it before that and no one drove it or anything. Is it at all possible that something is out of adjustment or something??
Old Sep 19, 2009 | 07:10 AM
Were you driving a different stick shift car for that week?
Old Sep 19, 2009 | 10:09 AM
viperboy's Avatar
Nope, just a rental auto Mustang Convertible. I went through that in my head too. I'm not wearing different shoes and the seat is all the way back like it always is.
Went to the mechanic and the slave cylinder fluid was low, topped that off and it didn't help. He checked underneath the car and removed the inspection plate (didn't have him remove the crossmember so it was hard to see) but he said that everything seemed fine. He ran his fingers in there and they came back a little black but nothing excessive.
So at this point, I have to think this is either the beginning signs of a going clutch or a bigger transmission problem.
Old Sep 19, 2009 | 10:28 AM
P. Samson's Avatar
It would have helped if the info in your last two posts had been included in your first post. It appears that you could have a slave or master leak/bypassing issue. What to you seems like a high engagement point could be more like lost motion between the master and the slave. If you hold the clutch pedal down for a minute or so with the engine idling in neutral is it hard to get into reverse or 1st without clashing the gears? Keep an eye on the fluid level for now but it sounds like you may have a fluid leak which may be an indication of a master or slave cylinder problem. How much pedal free play have you got?
Old Sep 19, 2009 | 11:18 AM
viperboy's Avatar
Probably unrelated... but my brakes have always felt squishy. I've had the lines replaced, fluid changed, and bled the brakes. Only thing I haven't done is changed the pads and rotors. Does the clutch and brake use the same cylinder? Like, the brakes work but I can be stopped and put the pedal on the floor without even trying. Possible cylinder problem?
I'll try the clutch in and car in N later when I go out today, but I have noticed a slight "clunk" going into 1st and 3rd recently.
And I would say the clutch used to start engaging about 1/3 of the way out and had a good amount of room before it fully engaged, but now it feels like it starts engaging like 1/2 way out and is short before it's fully engaged.
Old Sep 19, 2009 | 04:28 PM
QNO_A32's Avatar
if you can put your brake pedal on the floor than you have a problem
Old Sep 19, 2009 | 04:34 PM
viperboy's Avatar
Unfortunately, I'm not sure what that problem is and I'm wondering if it is somehow related to this clutch problem.
Old Sep 19, 2009 | 10:38 PM
The brake system is in NO WAY related to the clutch. Completely seperate, you could remove the entire braking system and the clutch would work fine. At least until you crashed the car
I wouldn't worry about the tranny going bad either. This is most likely a problem with the clutch/hydrolics.
At this point I would flush the clutch fluid. It could be that moisture collected in it and sitting for a week made it worse. It may not help but it's cheap and easy. You should rule it out before doing anything else.
Old Sep 25, 2009 | 10:30 AM
viperboy's Avatar
Ok, I am pretty sure it has to be something hydraulic related. When I pull a fast shift, it tends to grind and than drop in, which tells me that things aren't moving fast enough in the hydraulics. It also happens once the clutch engages, it feels like it slips but its not. Its just not grabbing right away.
So what are things that might need to be replaced? I don't know that a clutch flush is gonna help now.
Old Sep 25, 2009 | 11:33 AM
knight_yyz's Avatar
Toolie
I always thought the best way to test the clutch is to apply the parking brake and try to drive away. If the clutch slips, the rpms will rise and the car won't move. If the clutch is good the car should want to stall.
Old Sep 25, 2009 | 12:29 PM
It sounds like you have a problem with diesngaging (grinding) AND engaging (slipping). Usually a hydrolic problem will cause a problem with disengaging. As you loose fluid or get air in the like you lose the ability for the clutch pedal to transfer the force to the clutch fork. That causes grinding because you can't fully disengage the clutch. Think of it like this. Hydrolics push it to disengage and the clutch springs force it to engage and not slip. With no hydrolics the clutch would be engaged. With no clutch the pedal would go to the floor and stay there. They work together.
If you're slipping it's usually the clutch material wearing out or the springs getting weak.
If your hydrolic lines are full of junk it could cause a problem with releasing and let it slip too. If the fluid can't travel through the lines smoothly it can have the effect of slowly releasing the clutch even if you dump it fast. Contaminated fluid can get worse from sitting too as the contaminates settle and clump up. Just do the fluid flush. You can do it in your driveway with the help of one person to just push the pedal. It'll cost you about $4.00 in fluid.
Old Sep 25, 2009 | 12:37 PM
That works too but you can still stall the car unless it's really slipping bad. If it's just starting to get weak that wont tell you anything.
When I think of a clutch slipping I'm talking about not being able to bark the tires going into 2nd or 3rd. Normal driving will still be fine for a while. Spinning the tires in 1st can still be possible for a while but you know it needs to be handled soon.
Old Sep 29, 2009 | 08:23 AM
sontakke's Avatar
The trouble with testing to see if the clutch is slipping is that if it was not slipping before it will most likely slip after! Clutch slipping test is a destructive test. If you think or know it is slipping, don't do any test on it but add coins to your piggy bank for the clutch replacement budget :-)
- Vikas
user 11122324
42
Jul 18, 2022 03:35 PM
Mar 12, 2020 12:06 AM
spencerwh1
Jun 30, 2016 05:44 AM
BkGreen97
Apr 2, 2016 05:47 AM
carlosvq30
Sep 26, 2015 09:44 AM
