245/50/18 on a 5.5 Gen Maxima
hey I've come across someone selling a set of 4 rims w/ new tires from an 03 Z
235/50/18 (2)
245/50/18 (2)
will an 03 Max accomodate 245???
My GLE has 225/50/17 currently but Im looking to upgrade and this guy has a GREAT deal on his set...
235/50/18 (2)
245/50/18 (2)
Im currently running 350Z touring wheels and 245/45zr18 Nitto 555's and I can stop rubbing on the passengers side. (not to steal your thread) but can anyone give me advice from experience what to do??
But for your situation i think the size is going to give you problems no matter what.
S
Just run 245/40/18...these are closer to what you should be running! Those 245/50/18 aspect ratio is so large that you can't help but rub...and to those with the stock suspension it'll rub since the dampening is softer!
This question is asked every time someone mentions they're getting Z rims. Well the answer is; because we can. Do you really spend your time looking to see if the Z rims on the Maxima's you come across are all the same size? Get a life; I have my wider wheels on the front this very minute.
Not to mention that no one is going to notice the difference. Plus, with the rears being sunken in stock, wider rears actually fill out the well and make it more even. Which, actually gives it a better look.
No hating unless you have a valid argument against it.
i just picked them up. i cant wait to put em on tomorrow.
alot of people missed my second post CORRECTING the first, they are actually 245/45/18 and 225/45/18
im thinking of putting the fat ones in the front...better traction and such...though im not sure, im having a hard time deciding where to place the fat ones...
are they 245/45 all around????
You can put the 245s in front but it just makes the front look more offset. Some 20mm rear spacers would do the trick though. Those should be mandatory for these damn things. Nissan was hittin the crack pipe on some of these designs.
what kind of tire/rim set up do you have????
Finkle
09-27-2015 09:53 PM
