Stumped!!!! NO horn No Steering wheel controls SRS light
Old Sep 27, 2009 | 04:43 PM
2000MilkedMax's Avatar
Now this weekend my brother and I replaced the rack and pinion on my 03 maxima...At first I thought my SRS light was flashing maybe due to low voltage to the ecu from me leaving the key in the ignition over night and waking up to a dead battery...But after I jumped it and tried the SRS reset procedure a couple times and checking the fuses I went for a drive and attempted to press the button to change the CD track(after I did some parking lot figure eights and a highway run) and it didnt budge. So I came home and troubleshoot it some more and noticed that my horn doesnt work niether...Im stumped as to what to look at next... any suggestions?
*edit*
The only interior work that was needed was to remove the 3 nuts that hold the steering column right behind the pedal.
Old Sep 27, 2009 | 04:52 PM
VQP0WER's Avatar
You must have unplugged or damaged the harness going to the steering column?
Old Sep 27, 2009 | 05:01 PM
Where is it located??? Pic??? Color of plug???
*edit* I see the sm in ur sig...and my bro is on his way with ALLDATA ne how...
Old Sep 27, 2009 | 06:48 PM
Yep...rotated it one to many times...Thanks
Old Sep 28, 2009 | 05:26 AM
cjones450's Avatar
you sir need a clock spring its behind the steering wheels there kind of expensive but not to bad
Old Sep 28, 2009 | 05:48 AM
rcg9999's Avatar
CLOCK SPRING CHECK http://www.txnissanparts.com/Scripts/default.asp
Old Oct 12, 2009 | 07:16 PM
Clock Spring was $60 from nissan....Fixed...
MikesChevelle
Nov 23, 2024 11:17 AM
trasmadean
Feb 1, 2017 08:20 PM
vingodine
45
May 21, 2016 12:46 PM
Flores94
Aug 13, 2015 01:17 PM
MikesChevelle
Aug 6, 2015 11:36 AM
