How to: Run amp power cable through firewall in 5th gen
There's a cutout diamond in the padding underneath the dash on the driver's side. It's even got a thumb tab to make it easy to remove. If you remove the cutout piece, you see bare metal underneath. That's the firewall. If you drill through it, you get right into the engine bay. Drilling is easy, the metal is pretty thin and there's not much in the way in the engine bay that you can accidently cut. You should drill from the inside of the car into the engine bay. I'm guessing 4-gauge amp power cable is about half an inch in diameter, so you can drill one big hole if you have the drill bit. I had to drill several small holes, then widen them with a bigger bit and punch out the middle metal. The edges are sort of jagged, so I have to get a rubber grommet.
Re: Re: How to: Run amp power cable through firewall in 5th gen
Originally posted by pinakbet
I ran mines thru the existing rubber grommet for the hood release. There's also a rubber grommet w/ a wire harness going thru.
bp
bp
Ya don't hafta disassemble the dash. You can access the grommets by removing the plastic lining in the wheel well. Turning the wheel all the way to the left helps. Then when you feed the cable thru, it drops by the dead pedal. Didn't have a drill at the time so I did it that way. To each his own. . .
Peace,
bp
Peace,
bp
Peace,
bp
Peace,
bp
i have a 94 max
i spent hours trying to get the wire thru some hole to the battery without drilling
help me, find me a way, where is the firewall how do i get it thru
i feel like puttin my foot thru the windshield and running it thru it lol
nooo
lets not
i love my max
nooo
lets not
i love my max
Re: i have a 94 max
Do a search in the audio\electronics forums, several people have instructions for your 4th gen (?)
nooo
lets not
i love my max
nooo
lets not
i love my max
I do not suggest drilling thru the firewall. I had my fog lights installed at on my GXE, and wanted them to mount a switch on the dashboard. Suckers made a huge hole in my then brand-new Max but couldn't get through, so I told them to leave it. On the other hand, install guys @ stereo shop easily run a wire...not sure where, but across from the passenger side in the engine bay...
Finkle
09-27-2015 09:53 PM
Viralkill
08-17-2015 10:54 AM
