Fuel Delivery Question
Old Oct 19, 2009 | 08:57 AM
nismax96's Avatar
I've been having a problem starting the Max. It won't start unless I'm stepping on the gas pedal. This really wasn't an issue until this weekend. I'm driving and all of sudden the interior lights get dim and the engine stops. I put the car in park and start it up again. Give it some gas and everything sounds good until I put the car in drive. Everthing shuts down again. I was thinking transmission at first, but reverse was fine and did not cut off. Only in drive does it stop. Is this a fuel delivery problem or what else could it be?
Old Oct 19, 2009 | 09:08 AM
NissanMan97's Avatar
i had a similar problem with my 4th gen...it was the crank shaft position sensor but i was also throwing codes.
in the bolded part...were you moving or had you come to a stop and it shut off? if you came to a stop it sounds like my probe and the idle sensor and EGR went out but i didnt throw codes on that. if you were moving...same thing happened to me in my 02...im pretty sure it was something on the MAF and it cleared off cause it hasnt done it sense
B
Old Oct 19, 2009 | 09:15 AM
nismax96's Avatar
I was in the middle of making a turn when it first stopped. The second time I was at a light. Its not throwing any codes at all.
Old Oct 19, 2009 | 09:18 AM
plug it up and check just incase...ive seen weird **** happen where it wont throw codes until its hooked up to a reader, mind you that was on a ford probe...
also i would go some where and get the fuel pressure tested that may answer you question. to me it sounds like low fuel pressure but im far from experienced so take it for what it is worth.
B
Old Oct 19, 2009 | 09:43 AM
nismax96's Avatar
I will have to hook up the scanner tonight. I'm actually scared to drive it because It keeps shutting off. Can I use fuel injector cleaner to see if that works?
Old Oct 19, 2009 | 09:52 AM
i guess...but i would check the fuel pressure before using additives
B
Old Oct 19, 2009 | 10:00 AM
nismax96's Avatar
Forgive my ignorance, but how do I check the fuel pressure?
Old Oct 19, 2009 | 10:48 AM
you will have to take it some where...autozone, pepboys or a nissan dealer
B
Old Oct 19, 2009 | 07:26 PM
jasonmax's Avatar
clean your idle valve
I think this is more air related not fuel
Old Oct 20, 2009 | 05:56 AM
nismax96's Avatar
I hooked up the scanner this morning. No stored or pending codes. I was hoping I didn't have to take it to the dealer, but I will try and clean the idle valve as suggested before I do.
VQ'ed
Forced Induction
Feb 29, 2016 08:05 AM
bumpypickle
Sep 20, 2015 08:22 AM
carid
Sep 17, 2015 05:00 AM
conansriver
Sep 11, 2015 10:26 AM
