New Alternator - New Noises
Old Oct 21, 2009 | 09:37 PM
4DSCDriver's Avatar
Well, just got done installing an OEM alternator in the Max. Actually wasn't all that hard. Anyway, after the install, I've got some new noises. Ther seems to be a whistling noise coming from somewhere around the alternator. This noise builds consistant with the rpms. I'm also getting a "poof" sound coming from the idler pulley that is consistant with rpms as well.
I can't here these noises while driving, but during idle at stop lights and from outside the car, I can really here it. Any ideas? Thanks in advance.
Old Oct 21, 2009 | 11:44 PM
asma123's Avatar
I just replaced my alternator as well, and I just realized I got a leak of coolant somewhere. I really hope it's not my rad and with 80,000km I really don't know what to think. I'm assuming the noise you're hearing is the belt that goes on the alt check with a mechanic and check on it. you may need to replace the belt. as for the poof sound, any more detail?
Also a bit off topic but how did you manage to post a thread? I've tried to post threads, and I keep getting the message
asma123, you do not have permission to access this page. This could be due to one of several reasons:
  1. Your user account may not have sufficient privileges to access this page. Are you trying to edit someone else's post, access administrative features or some other privileged system?
  2. If you are trying to post, the administrator may have disabled your account, or it may be awaiting activation."
I have not received any activation e-mails, but the welcome to the forum e-mail
Old Oct 22, 2009 | 05:54 AM
4DSCDriver's Avatar
The belt is new so I know thats not an issue.
I also noticed that in the process of the old alt going bad and installing the new one, I lost a couple dash lights. One on the cluster, one on the radio and two A/C buttons. Somtimes I wish I wasn't OCD....thats going to drive me nuts.
Hmm, more specific on the poof sound? Well, sounds sort of like two popsicle sticks tapping against each other.
Old Oct 22, 2009 | 07:23 AM
Phantom-V's Avatar
I just had a similar problem with mine. Just replaced mine about 2 weeks ago. Check the Alternator tensioner. make sure that your belt is on there tight. the tensioner is located right by the alternator.
here is a link to my thread with a picture towards the bottom of what im speaking out. http://forums.maxima.org/5th-generat...ine-noise.html
once i tightend mine, the noise went right away. also, make sure your hoses that you moved out of the way to get the alternator down are secure and tight. i rechecked mine when i removed mine just to make sure.
Old Oct 22, 2009 | 07:38 AM
Lontar1's Avatar
Puerto Rico-Maxima Lover
check the Belt tensioner... that's where your problem is
user 11122324
42
Jul 18, 2022 03:35 PM
D Mason
Jun 21, 2016 04:43 AM
uttadms31
Sep 30, 2015 05:24 AM
